block attributes
block attributes
block attributes
I have a block which i need to use in many drawings in a day (block dwg attached). For one project I use same block for different drawing. Where following attributes value DRAWING TITLE, DRAWING TITLE LINE 2, OPTION CODE, SCALE, TOLERANCE SPEC, G.O. NUMBER, ECO NUMBER remain same for all drawings of 1 project. This values I get from one notepad file (project details.txt file attached). Currently I am doing - if in any drawing i want to use this block i copy this block from block.dwg file & then change all attributes one by one, if I am using this block in 10 drawing of 1 project then i have to change same attributes value in all 10 drawings.So i need a programme where I will use this notepad to udate the block. Please help Thanking you in anticipation
ВeekeeCZ
Try Lee's BATTE routine HERE.
