Pick a point between polylines then create internal polylne with radius 50.0
J-Rocks
Message 1 of 10
J-Rocks
I am having a hard time to know to to be able to create a internal polyline between polylines with fillet of 50.0 units as in the attached image and drawing.
Hope someone to help me with this.
Thanks in advance.
Replies (9)
Message 2 of 10
ВeekeeCZ
Guess you are talking about offset............
(vl-load-com)
(defun c:IntOffset50 ( / pt)
  (if (setq pt (getpoint "\nInternal point: "))
    (progn
      (setvar 'FILLETRAD 50)
      (vl-cmdf "_.-BOUNDARY" "_none" pt "")
      (vl-cmdf "_.OFFSET" "_Erase" "_Y" 50 (entlast) pt "")
      (vl-cmdf "_.FILLET" "_Polyline" "_Last")
  (princ)
Message 3 of 10
J-Rocks
Thank you for your reply.
I need to pick a point in an opened area and your program does not work for this case.
Can you please modify your codes ?
Message 4 of 10
ВeekeeCZ
Not that simple.
But you can try this approach. If an area is opened, you will close it first - you'll select a first end, then a second - couter-clockwise!, and that's all you need to do.
Spoiler
(vl-load-com)
(defun c:IntOffset50 ( / *error* nVAR oVAR adoc p1 p2 pt enl)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (mapcar 'setvar nVAR oVAR)
    (vla-endundomark adoc)
    (princ))
  (vla-startundomark (setq adoc (vla-get-activedocument (setq aapp (vlax-get-acad-object)))))
  (setq oVAR (mapcar 'getvar (setq nVAR '(CMDECHO OSMODE ORTHOMODE SNAPMODE BLIPMODE FILLETRAD))))
  (mapcar 'setvar nVAR 			'(1	  33	 0	   0        0	     50))
  (if (and (setq p1 (getpoint "\nSelect first end of line (counter-clockwise) to close the area <area is closed>: "))
	   (setq p2 (getpoint p1 "\nSelect second end: "))
    (progn
      (setvar 'OSMODE 0)
      (vl-cmdf "_.LINE" p1 p2 "")
      (setq enl (entlast)
	    pm (polar p1 (angle p1 p2) (* (distance p1 p2) 0.5))
	    pt (polar pm (+ (angle p1 p2) (* pi 0.5)) 50))))
  (if (or pt
	  (setq pt (getpoint "\nInternal point: ")))
    (progn
      (vl-cmdf "_.-BOUNDARY" pt "")
      (if (and enl (entget enl)) (entdel enl))
      (vl-cmdf "_.TRIM" "" pm "")
      (vl-cmdf "_.OFFSET" "_Erase" "_N" "" "")
  (princ)
Message 5 of 10
J-Rocks
You changed the settings of my AutoCAD and did not re-set them back Smiley Frustrated
I am sorry I can not close the area.
Thanks for trying.
Message 6 of 10
ВeekeeCZ
Thanks for trying.
I see, sorry, not on purpose. One line missing. :(( I asked the modarator to remove the code.
Spoiler
(vl-load-com)
    (princ))
    (progn
      (setvar 'OSMODE 0)
      (setq enl (entlast)
  (if (or pt
    (progn
  (*error* "end")
Why? On your sample that works perfectly. Or is your sample to simplified?
Message 7 of 10
J-Rocks
No it is not simplified sample , it is as reality.
After closing the opened area, the opening new polyline does not direct the open segment of it to the correct side.
Message 8 of 10
ВeekeeCZ
Could be that fixed by reversing the polyline? If so, could you explain how to recognise which direction is correct?
Message 9 of 10
J-Rocks
Hello.
I expected from the program to recognise which direction is correct and really I have no idea.
Message 10 of 10
Kent1Cooper
If I understand how it works correctly, that would happen if you didn't follow the instruction to close the area with a Line going in the counter-clockwise direction.  Might you have picked the points for the closing Line in the wrong order?  But then, I would also expect the Boundary command to have a problem, because it looks like the point it would use to pick the area [the same one it uses for the Offset command] should be outside it, also....
One thing I have sometimes done in a similar situation, that doesn't depend on the direction in which a Polyline is drawn, is to use (vla-offset), which doesn't use a point to determine the direction of offset, but uses a positive or negative distance value.  Then I compare the Area of the resulting one to that of the original -- if the new one is smaller, it went inside, or if it's larger, it went outside.  If it went the wrong way for whatever the routine is doing, I have it delete that result, and do (vla-offset) again with the opposite sign on the distance value.
Kent Cooper, AIA
