Auto insertion of multiple dwg into a single dwg with LISP
I have 20 dwg files, each one containing one page of a projet (all the pages are the same size). I would like to combine them all into a single dwg file. Right now, in AutoCAD 2012, I manually insert the dwg and manually (with the mouse) position them in a row. Then I save and everything is fine.
Now, I have 500 dwg files to combine this way. I want to create a LISP script to automate the process. Right now I have the following, but it doesn't work. This is my first lisp script and I am more a C++ guy 😉
(defun C:MyInsert ()
(vl-load-com)
(setq x 0)
(foreach path (vl-directory-files "C:/Users/My folder/" "*.dwg")
(command "-insert" path "x,0,0" "" "" "")
(setq x (+ x 100))
My goal is to insert every dwg files in the folder, but to with an offset of 100 in x with regard to the last one inserted.
To test my function, in the LISP console:
LISP test insert
But is returns "nil" twice.
So, if anyone could help me understand this...
hmsilva
Untested....
(defun c:MyInsert ( / x)
   (vl-load-com)
   (setq x 0)
      (command "-insert" path (strcat (itoa x) ",0,0") "" "" "")
      (setq x (+ x 100))
   (princ)
Hope this helps,
Henrique
jdiala
(vl-load-com)
(setq x 0)
(command "-insert" (strcat "C:/Users/My folder/" path) (list x 0.0 0.0)  "" "" "")
(setq x (+ x 100))
jdiala
On your code "x,0,0", x is not evaluated hence giving you an error for a point. Also if "C:/Users/My folder/" is not in your support path, autocad will not be able able to find the file. So, concatenate the FolderName and the dwgname when you use insert.
sameerulcdc
hi
thank you for this lsp its working good
can u modify this lsp to existing block need to update with reference to insert from reference folder blocks
thank you in advance
baksconstructor
Use the Internet search for the word - "AutoImportCAD"
