Photo should open directly from the folder
sudarsann
sudarsann
Hello
Request you, I want to open the image using AutoLISP command in AutoCAD. Image path is in autocad in text format.
When I select text in AutoCAD, the photo should open directly from the folder. I need lisp code.
komondormrex
hey,
(vla-addraster (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
			   (cdr (assoc 1 (entget (car (entsel "\nPick raster image path text: ")))))
			   (vlax-3d-point (getpoint "\nPick point to insert raster image: "))
			   1
			   0
sudarsann
With your code image is opening in AutoCAD window by clicking a point, but my requirement is directly open the image from windows explorer by selecting only the path in AutoCAD .
Thanks and Regards
Sudarsan
paullimapa
try this opnpng.lsp
; opnpng function selects text containing image file name to open
; OP:
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/photo-should-open-directly-from-the-folder/m-p/13163091/highlight/false#M475062
(defun c:opnpng (/ en fil)
  (princ"\nPick Text Object...")
  (if(setq en (ssget  "_+.:E:S" '((0 .  "*TEXT"))))
    (if(findfile (setq fil (cdr(assoc 1 (entget (ssname en 0))))))
     (startapp "mspaint.exe" (strcat "\"" fil "\""))
     (alert(strcat "File Not Found: " fil))
  (princ)
Paul Li
IT Specialist
@The Office
