SSGET filter with block attribute value
traci_haberghamJQEJT
Message 1 of 12
Hi there,
I am trying to filter a selection of a block using block name, layer name and ideally I would like it to select the block if the attribute value is a certain value.
(setq exdemise (ssget "_X" (list '(0 . "INSERT") '(2 . "PG_Ann_Area_Roomtag_Pln_Dyn") '(8 . "PG_Annotation_RoomTag_Existing"))))
I would like to add to the filter for it to select blocks with attribute data tag AREATYPE which is equal to 'Ex Demise Area'.
Is this possible?  I've looked everywhere and can't find a solution.
Thank you
Traci
Replies (11)
Message 2 of 12
ВeekeeCZ
There is NO way to create ss filter for att tags or even its values. You need to select all inserts with atts '(66 . 1), then filter them out afterward.
Message 3 of 12
komondormrex
hey,
you cannot do this with ssget only. can be done with ssgetting attributed blocks and filtering out ones not suitable for a certain attribute tag and value selection.
Message 4 of 12
Thank you, is there any guidance on how to filter the attribute values, I don't know how to even see them in Autolisp?
Message 5 of 12
ВeekeeCZ
Do you know how to process the selection set?
https://www.lee-mac.com/selsetprocessing.html
BTW this part only works if blocks are NOT dynamic, are they?
Edit: Example for your case...
(if (setq exdemise (ssget "_X" (list '(0 . "INSERT") '(2 . "PG_Ann_Area_Roomtag_Pln_Dyn") '(8 . "PG_Annotation_RoomTag_Existing"))))
  (repeat (setq index (sslength exdemise))
    (setq ename (ssname exdemise (setq index (1- index))))
    (if (/= (getpropertyvalue ename "AREATYPE") "Ex Demise Area")
      (ssdel ename exdemise))))
Message 6 of 12
komondormrex
and lm free one
(setq insert_sset (ssadd))
(sssetfirst nil
			(foreach insert
					 (vl-remove-if-not '(lambda (insert) (and (= "PG_Ann_Area_Roomtag_Pln_Dyn" (vla-get-effectivename (vlax-ename->vla-object insert)))
					 										  (vl-some '(lambda (attribute) (and (= "AREATYPE" (vla-get-tagstring attribute))
																								 (= "Ex Demise Area" (vla-get-textstring attribute))
																	   	(vlax-invoke (vlax-ename->vla-object insert) 'getattributes)
										(vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget "_x" '(
																									(0 . "insert")
																								  	(66 . 1)
					 (ssadd insert insert_sset)
Message 7 of 12
Thank you, much appreciated.
I'll have a look at the link and no its not a dynamic block (not sure why its called that, was created before I joined).
Message 8 of 12
Thank you, greatly appreciated.  I'll have a look at sorting the selection set with the above to filter what I need.
Message 9 of 12
This works a treat - thank you (& lm too) 🙂
Message 10 of 12
Sorry its me again!  Just one question, I have updated my lisp to include the above so it narrows down my selection set to the relevant attributes but I don't think that the new selection set created by this takes all the information across - is this possible?    If I ran the table before it populated the area values but since updating the selection set using the attribute code it doesn't populate those attributes.  Any  ideas why?  Thank you (again!!)
Message 11 of 12
komondormrex
@traci_haberghamJQEJT wrote:
... I have updated my lisp to include the above so it narrows down my selection set to the relevant attributes but I don't think that the new selection set created by this takes all the information across - is this possible?
hardly, if only your attributes are not exactly same in writing in which case strcase will generally help. do you want to get area attributes value from every block in filtered selection set to put into the table generated?
need to see your updated code.
Message 12 of 12
Sorry it was user error, its all working great now.  Thank you 😀
