PDF to DWG
PDF to DWG
PDF to DWG
I want to just simply create a DWG file using PDF's but without continuously using the PDF attach command? I am currently using AutoCAD2015. Can a LISP be created in AutoCAD that will allow me to generate sheet sets that will ultimately allow a user to select PDF's without constantly typing PDF attach to create drawings in large amounts? The reason is because my company will be assuming large amount of drawings to reflect our design of the plant.
paullimapa
Open Windows Explorer, select the PDF, drag & drop it into the AutoCAD 2015 graphics screen.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
