Path to the current lisp file, and a return value from shell
While lisp file is executing, is it possible to get a full path to it with a script command?
Is it possible to get a return value from shell into lisp file? eg would like to execute something like "shell chdir" and get a current directory back into a variable in a lisp file.
Thank You.
scot-65
Perhaps look into FINDFILE and/or VL-FILENAME-DIRECTORY?
Is the LISP loaded via CUI or APPLOAD?
If so, you may be out of luck?
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Thanks for the reply. It is acad.lsp file, but it could be on different folders as users could have it on different folders. I guess findfile probably works the same way as the code which is used by autocad to locate acad.lsp, so in theory it should find itself first?
dgorsman
That entirely depends if (load ...) was called without a path, or if (findfile ...) or a functionally similar process was used to provide a full path.  Otherwise there is no "generic" means of telling where a LISP was loaded from e.g. a different file search function was used, or a user drag-dropped the LISP file into the active drawing.
If its crucial for you to know where LISP files have been loaded from create your own wrapper function which calls (load ...).  You can then keep track of where individual files are loaded from.
