Rectangular Revcloud Command via lisp...?
cchiles
Message 1 of 12
cchiles
Using Autocad 2016
I have tried this several ways...
Every time I run the "revcloud" command through lisp I seem to get an old "revcloud" command that doesn't have "rectangular" as an option - unlike typing "revcloud" through the command line:
Here's my code trying "R" option:
(defun C:rrv ()
(command "revcloud" "r" "S" "C" "A" (* 0.25 (getvar "DIMSCALE")) "")
;;;Pause for user input:
(while (= (logand (getvar "cmdactive") 1) 1)
(prompt "\nDraw RevCloud\n")
(command pause)
;;;end of Pause
(princ)
I've also tried setting it via the system variable first: (setvar "revcloudcreatemode" 1)
(which is where the "R" option in the command line version seems to be stored) but because the lisp activated "revcloud" seems to be an old one (or something) - it always defaults to "freehand" regardless of that sys var setting.
Here is the code with the sys var
(defun C:rrv ()
(command "revcloud" "S" "C" "A" (* 0.25 (getvar "DIMSCALE")) "")
(command pause)
;;;end of Pause
(princ)
Anyone have any thoughts?  This is making me crazy!
Chris
Thanks in advance!
-Chris
Replies (11)
Message 2 of 12
rkmcswain
Maybe this?
(defun c:foo ()
  (initcommandversion 2)
  (setq a (getpoint "\nPick first point: "))
  (setq b (getcorner a "\nPick other corner: "))
  (vl-cmdf "._revcloud" "_R" a b )
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 12
Kent1Cooper
In case it's of use to you, here's what I have used for that -- RectRevCloud.lsp with its RRC command.  It includes some control over the arc size by asking how many bulges you want along the longer sides of the rectangle, and the option of whether to bulge outward or inward.  There are some things about it that I would do a little differently today, but I did test it in Acad2016, and it still works.  [There's an earlier and shorter but less sophisticated version on a couple of other threads, if you Search for RectRevCloud.]
Kent Cooper, AIA
Message 4 of 12
cchiles
Excellent!Using your suggestion I was able to create a lisp for freehand, & polygonal
Using your suggestion I was able to create a lisp for freehand, & polygonal revclouds as well.
Thanks so much!
-Chris
Thanks in advance!
-Chris
Message 5 of 12
andrew_keen
Did you find a solution to invoke the "new" revcloud command instead of the old one? I understand these answers do work, but I would rather not rewrite my existing code.
Message 6 of 12
andrew_keen
Had a further dig and found and tested the solution.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-AutoLISP/file...
Basically, you need to add the line
before your revcloud command and it will use the current version.
Message 7 of 12
THANK YOU VERY MUCH...
Message 8 of 12
Ed__Jobe
Hi @rkmcswain
I can't get this to work in 2023. Everything I try won't let me select points. Here's the F2 from your command.
Command: (defun c:foo ()
(_>   (initcommandversion 2)
(_>   (setq a (getpoint "\nPick first point: "))
(_>   (setq b (getcorner a "\nPick other corner: "))
(_>   (vl-cmdf "._revcloud" "_R" a b )
(_> )
C:FOO
Command: FOO
Pick first point:
Pick other corner: ._revcloud
Minimum arc length: 19'-4.7795"   Maximum arc length: 38'-9.5590"   Style: Normal   Type: Rectangular
Specify first corner point or [Arc length/Object/Rectangular/Polygonal/Freehand/Style/Modify] <Object>: _R
Specify opposite corner:
Invalid shape to create revision cloud.
Ed
How to post your code.
Message 9 of 12
Ed__Jobe
@Kent1Cooper Kent, do you have any ideas why 2022 and 2023 would not accept point selection?
Ed
Message 10 of 12
Kent1Cooper
Is there other stuff in the vicinity, that it might be Osnapping to in a way that makes a flat/empty rectangle?  Does it work if you make sure running Osnap is off?
OR, in my code, what if you change this:
  (command "_.rectangle" cor1 cor2)
to this:
  (command "_.rectangle" "_non" cor1 "_non" cor2)
and similarly in @rkmcswain's code?  There, it looks from your command history like the problem isn't with accepting point selection, but with the process using those points.
Kent Cooper, AIA
Message 11 of 12
Ed__Jobe
No, there isn't anything near where I'm selecting. I even tried it in a blank dwg. If I use RK's code, the revcloud command doesn't process the points. If I just use the code below, it prompts for points but doesn't accept them. Does either line below work for you?
(vl-cmdf "._revcloud" "_R")
(command-s "._revcloud" "_R")
I just tried it on my laptop at home with MEP 2023 and RK's function worked. So there is something different about my work pc, where I'm using acade 2023. I used vars2scr to capture my home settings and tomorrow I'll compare with my work pc.
Ed
Message 12 of 12
ВeekeeCZ
This works in 2022. I think it hasn't changed in 2023, but can't really test it.
(defun c:RC ()
  (initcommandversion)
  (command-s "_.revcloud" "_r" pause pause)
  (princ)
