Passing a lisp variable to a block attribute insterted with a menu macro
Message 1 of 11
The lisp
      (setq userr1 (getreal "\n Wattage?"))
The menu macro
[MVDEC_009,DEC SF MTD]^C^C^P-insert MVDEC_009 \!userr5 ;\;;;!userr1 ;;;;;;;;;;;;;;;;;;;;;;;^P
the block has 26 tags. The Wattage tag is fourth.
!userr5 is a scaling value for the block and works fine but !userr1 comes in as text instead of the value ie 40.4
Also do I have to use one of the global variables like userr1 or can I use a normal variable like wts
I have searched for a solution here but not found one.
Replies (10)
Message 2 of 11
john.uhden
I am just guessing here, but since attributes are just like text, maybe you should be supplying a string value instead of a real.
Also, I don't think scripts take AutoLisp symbols.
So, how about trying...
(setq mts (getreal "\n Wattage?"))
(setvar "users1" (rtos mts 2 1)) ; or whatever precision you want.
Then use users1 in your script.
John F. Uhden
Message 3 of 11
I think you have hit the nail on the head yes absolutely true if you were passing a variable to a block using lisp then you would have to convert it. I will try that right after afternoon coffee!
Message 4 of 11
Nope I have tried some variations and it's still not working
this works for the scale
 So in this case it's asking for a scale factor and accepts
ID_Ps100  [Plot Scale 1:100]^C^C^P(setq userr5 2) ^P
[MVDEC_009,DEC SF MTD]^C^C^P-insert MVDEC_009 \!userr5 ;\;;;;;;;;;;;;;;;;;;;;;;;;;;;^P
But I still can't pass text or a number to an attribute
Message 5 of 11
ВeekeeCZ
I would use a lisp instead of macro for the button.
(command "-insert" "12" pause 1 1 0 (getvar 'users1))
Message 6 of 11
Trouble is the block is selected from a slide as in
ID_Mvfits  [Insert MV Fits]^C^C^P(if (= userr5 nil)(setq userr5 1))(if (not mfitlayer)(load "mfitlayer.fas"))(mfitlayer)
mfitlayer is lisp making or setting the right layer current then switches to a window containing slides of the blocks
\^P$I=SLD.image_MVFits_New $I=SLD.*
so the user clicks on the slide of the block he wants then
**image_MVFITS_New
[MAINS VOLTAGE FITTINGS]
[MVDEC_009,DEC SF MTD]^C^C^P-insert MVDEC_009 \!userr5 ;\;;;users1 ;;;;;;;;;;;;;;;;;;;;;;;^P
which inserts the block on the right layer at the right scale and hopefully the correct wattage in the fouth attribute tag.
Message 7 of 11
ВeekeeCZ
How about insert a block using macro without attributes and then run a lisp which put attributes back on the block just created? Something like (setattributes (entlast) (getvar 'users1)) - some routine for that you can find on Lee's page HERE
...because I don't think we can find the way to evaluate the variable (or a lisp code) right away.
Message 8 of 11
Maybe after inserting the block with a default value of zero for watts then run a lisp to select last object (the block) and insert the value into the tag in the normal way with lisp? Provided I can call the lisp with the macro after inserting the block.  Messy though.
Message 9 of 11
ВeekeeCZ
Yes, that's what I meat - you can set 'attreq 0 to get no att prompts... or just put a proper mount of ;;;
Message 10 of 11
Kent1Cooper
If you set the TEXTEVAL System Variable to 1, you can feed text contents from any variable [whether one of the USERSx ones or your own] into a command macro in either of two ways:
!YourVariableName
or
(eval YourVariableName)
Kent Cooper, AIA
Message 11 of 11
Thanks Kent! at last it's working and good to know how to do it as it could come in useful in future.
