Export coordinates of selected object (arc or line) to excel
danijel.radenkovic
Message 1 of 16
danijel.radenkovic
Hello to all,
I believe there is a script, lisp, vb.net application or whatever, which recognize type of selected object (arc or line) and export object's coordinates.
For arcs, I would like to export start point, center of arc and end point. For lines I would like to export start and end point.
Attached example of connected arcs and line represents my problem.
Any help is very appreciated.
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
Accepted solutions (3)
Replies (15)
Message 2 of 16
ВeekeeCZ
Try following code. Some things that you can adjust yourself.
- in your country is a CSV file separated by a comma or a semicolon? Used comma
- do you want to z coords?
- lines are presented with 0 0 0 for the center point.
(vl-load-com)
(defun c:LA2CSV ( / *error* file i en pe pm pb)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if file (close file))
    (princ))
  (if (and (setq ss (ssget '((0 . "LINE,ARC"))))
           (setq file (open (strcat (getvar 'DWGPREFIX) (vl-string-right-trim ".dwg" (getvar 'DWGNAME)) "-CooExport.csv") "a"))
           (write-line "x1,y1,z1,xm,ym,zm,x2,y2,z2" file)										; delimiter
    (repeat (setq i (sslength ss))
      (setq en (ssname ss (setq i (1- i)))
            pb (vlax-curve-getStartPoint en)
            pe (vlax-curve-getEndPoint en)
            pm (if (= "ARC" (cdr (assoc 0 (entget en))))
                 (cdr (assoc 10 (entget en)))
                 '(0 0 0)))
      			  ;x			  y			z
      (write-line (strcat (rtos (car pb) 2 8) "," (rtos (cadr pb) 2 8) "," (rtos (last pb) 2 8) ","					; delimiter
                          (rtos (car pm) 2 8) "," (rtos (cadr pm) 2 8) "," (rtos (last pm) 2 8) ","					; delimiter
                          (rtos (car pe) 2 8) "," (rtos (cadr pe) 2 8) "," (rtos (last pe) 2 8)						; delimiter
                          ) file)))
  (princ (strcat "\nFile exported: "(getvar 'DWGPREFIX) (vl-string-right-trim ".dwg" (getvar 'DWGNAME)) "-CooExport.csv"))
  (*error* "end")
Message 3 of 16
danijel.radenkovic
-it works fine as I expected with "."
-I don't need z coords, just x and y
-it is ok
One thing that I would like to change is to export points into the opened excel doc starting from the A1 cell every time. If I open already filled sheet with data (coordinates), it has to clear all sheet and export new values starting from the first cell.
Thank you!
Message 4 of 16
ВeekeeCZ
Sure.
My first question wasn't about the decimal delimiter but the column delimiter. But lets keep it.
No sure if you want the heading line or not - see the code, erase or keep the initial semicolon.
(vl-load-com)
(defun c:LA2CSV ( / *error* file i pb pm pe en)
    (princ))
           (setq file (open (strcat (getvar 'DWGPREFIX) (vl-string-right-trim ".dwg" (getvar 'DWGNAME)) "-CooExport.csv") "w"))
          ; (write-line "x1,y1,xm,ym,x2,y2" file)				; heading
                 '(0 0 0)))
      			  ;x			  y
      (write-line (strcat (rtos (car pb) 2 8) "," (rtos (cadr pb) 2 8) "," 					; delimiter
                          (rtos (car pm) 2 8) "," (rtos (cadr pm) 2 8) ","					; delimiter
                          (rtos (car pe) 2 8) "," (rtos (cadr pe) 2 8)						; delimiter
                          ) file)))
  (*error* "end")
Message 5 of 16
danijel.radenkovic
@ВeekeeCZ wrote:
Sure.
I agree to keep column delimiter. Heading line is ok and I will keep it (I have erased red code). The only thing that I noticed is that it doesn't work with the opened .csv (as it is showed on the video). Also, I have never used .csv files but standard .xsl and .xlsx documents cause Inventor allows me to import only those two extensions.
Message 6 of 16
ВeekeeCZ
I wasn't meant for that. I've found this @patrick_35's example which works with open Excel sheet.
For some reason (probably a country specific - comma vs semicolon) the original HERE exports just the x coordinates.
I've made some modifications in the code to accept ACRs as well, but Y coord you need to add by yourself - if this solution works for you better.
Good luck
; by patrick_35
; mods by beekeecz
(vl-load-com)
(defun c:test(/ doc ent lin xls wks)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-startundomark doc)
  (and (ssget '((0 . "LINE,ARC")))
    (progn
      (setq xls (vlax-get-or-create-object "Excel.Application"))
      (or (setq wks (vlax-get xls 'ActiveSheet))
	(vlax-invoke (vlax-get xls 'workbooks) 'Add)
	    lin 2
      (vlax-put xls 'Visible :vlax-true)
      (vlax-put (vlax-get-property wks 'range "A1") 'value "StartPoint-X")
      (vlax-put (vlax-get-property wks 'range "B1") 'value "EndPoint-X")
      (vlax-put (vlax-get-property wks 'range "C1") 'value "Center-X")
      (vlax-for ent (setq sel (vla-get-activeselectionset doc))
	(vlax-put (vlax-get-property wks 'range (strcat "A" (itoa lin))) 'value (car (trans (vlax-get ent 'startpoint) 1 0)))
	(vlax-put (vlax-get-property wks 'range (strcat "B" (itoa lin))) 'value (car (trans (vlax-get ent 'endpoint) 1 0)))
        (vlax-put (vlax-get-property wks 'range (strcat "C" (itoa lin))) 'value (car (if (= "AcDbArc" (vlax-get ent 'objectname))
        (trans (vlax-get ent 'center) 1 0)
        '(0 0 0))))
        (setq lin (1+ lin))
      (vla-delete sel)
      (mapcar 'vlax-release-object (list wks xls))
      (gc)(gc)
  (vla-endundomark doc)
  (princ)
Message 7 of 16
danijel.radenkovic
I have tried to figure out the code and to make similar for Y coordinates but I have some difficulties to understand cause I am not professional users of lisp.
      (vlax-put (vlax-get-property wks 'range "C1") 'value "EndPoint-X")
      (vlax-put (vlax-get-property wks 'range "E1") 'value "Center-X")
	(vlax-put (vlax-get-property wks 'range (strcat "C" (itoa lin))) 'value (car (trans (vlax-get ent 'endpoint) 1 0)))
        (vlax-put (vlax-get-property wks 'range (strcat "E" (itoa lin))) 'value (car (if (= "AcDbArc" (vlax-get ent 'objectname))
                                                     					'(0 0 0))))
Here what I have tried:
	(vlax-put (vlax-get-property wks 'range "B1") 'value "StartPoint-Y")
      	(vlax-put (vlax-get-property wks 'range "D1") 'value "EndPoint-Y")
     	 (vlax-put (vlax-get-property wks 'range "F1") 'value "Center-Y")
	(vlax-put (vlax-get-property wks 'range (strcat "B" (itoa lin))) 'value (car (trans (vlax-get ent 'startpoint) 0 1)))
	(vlax-put (vlax-get-property wks 'range (strcat "D" (itoa lin))) 'value (car (trans (vlax-get ent 'endpoint) 0 1)))
        (vlax-put (vlax-get-property wks 'range (strcat "F" (itoa lin))) 'value (car (if (= "AcDbArc" (vlax-get ent 'objectname))
        (trans (vlax-get ent 'center) 0 1)
        '(0 0 0))))
Where I am doing something wrong?
Message 8 of 16
ВeekeeCZ
Last 1 0 keep as it is - its from the TRANS function, see HERE
You need to change car to cadr. See my first routine - you dealing with the coordinates in list '(x y z). car takes the first one, cadr the second... see HERE and other links down the page.
Message 9 of 16
danijel.radenkovic
; by patrick_35
; mods by beekeecz
(vl-load-com)
    (progn
	    lin 2
                                                      					'(0 0 0))))
	(vlax-put (vlax-get-property wks 'range (strcat "B" (itoa lin))) 'value (cadr (trans (vlax-get ent 'startpoint) 1 0)))
	(vlax-put (vlax-get-property wks 'range (strcat "D" (itoa lin))) 'value (cadr (trans (vlax-get ent 'endpoint) 1 0)))
        (vlax-put (vlax-get-property wks 'range (strcat "F" (itoa lin))) 'value (cadr (if (= "AcDbArc" (vlax-get ent 'objectname))
        '(0 0 0))))
	(setq lin (1+ lin))
      (vla-delete sel)
      (gc)(gc)
  (princ)
I am getting the answer (error) "nil".
Message 10 of 16
ВeekeeCZ
; by patrick_35
; mods by beekeecz
(vl-load-com)
    (progn
	    lin 2
                                                      					'(0 0 0))))
        '(0 0 0))))
        (setq lin (1+ lin))
      (vla-delete sel)
      (gc)(gc)
  (princ)
Message 11 of 16
danijel.radenkovic
That's it!
Thank you. I am looking into the code where I made mistake. Very appreciate your help!
Message 12 of 16
danijel.radenkovic
Hello to all,
Apologize for my return on the this topic but I my question is close related to it. I would like to find a way to round the values of coordinates (for example on 6 decimals) before I export it to excel. Excel give me abilities to round it but just "visual", real value is still with many decimals.
Message 13 of 16
CADaSchtroumpf
You can simply change
to
(vlax-put (vlax-get-property wks 'range (strcat "A" (itoa lin))) 'value (read (rtos (car (trans (vlax-get ent 'startpoint) 1 0)) 2 5)))
Make same for "B","C","D","E","F": (read (rtos ....  2 5)), 5 is precision, put what you wont!
Message 14 of 16
danijel.radenkovic
I have changed as you adviced but I really don't know why it doesn't work. Am I doing something wrong with the editing?
(vl-load-com)
(defun c:Pera(/ doc ent lin xls wks)
    (progn
	    lin 2
        (vlax-put (vlax-get-property wks 'range (strcat "B" (itoa lin))) 'value (read (rtos (cadr (trans (vlax-get ent 'startpoint) 1 0)) 2 5)))
	(vlax-put (vlax-get-property wks 'range (strcat "C" (itoa lin))) 'value (read (rtos (car (trans (vlax-get ent 'endpoint) 1 0)) 2 5)))
        (vlax-put (vlax-get-property wks 'range (strcat "D" (itoa lin))) 'value (read (rtos (cadr (trans (vlax-get ent 'endpoint) 1 0)) 2 5)))
        (vlax-put (vlax-get-property wks 'range (strcat "E" (itoa lin))) 'value (read (rtos (car (if (= "AcDbArc" (vlax-get ent 'objectname))
        (trans (vlax-get ent 'center) 1 0) 2 5))
                                                      					'(0 0 0))))
        (vlax-put (vlax-get-property wks 'range (strcat "F" (itoa lin))) 'value (read (rtos (cadr (if (= "AcDbArc" (vlax-get ent 'objectname))
        '(0 0 0))))
        (setq lin (1+ lin))
      (vla-delete sel)
      (gc)(gc)
  (princ)
Message 15 of 16
CADaSchtroumpf
For "E" and "F", you have misplaced the argument of (rtos)
                                                      					'(0 0 0))) 2 5)))
        '(0 0 0))) 2 5)))
Message 16 of 16
danijel.radenkovic
                                                      					'(0 0 0))) 2 5)))
        '(0 0 0))) 2 5)))
I see now where I made mistake.
Thank you very much!
Danijel
