Partial Menus - Profiles
Message 1 of 11
AutoCAD 2014....
Are Partial Menu settings (menus that are loaded)...transfer over, or are they saved, in PROFILES?
Setting up company deployments.....Loading exported PROFILE with /p switch.
Everything comes across to the new users setup...except the Custom Menus...which were loaded as Partial Menu's
I know it used to work...because this same method...is how we deployed....way back...I ithink using AutoCAD 2004...
Maybe something has changed.
Replies (10)
Message 2 of 11
CSM_MAI
If you run an enterprise .cuix file along with a User .cuix file, I would attach them to the Enterprise. That's what I have done in the past. That way if your support files are on the server and you modify them, the next time the User opens AutoCAD, the changes will be current. Same goes if you add a new partial menu, it should show up if it's a part of the workspace.
The below link should provide some information on enterprise cuix files if you aren't familiar, apologies if you are.
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Au...
Message 3 of 11
Thanks for the Reply....however....I am simply asking the Question...."Do PArtial Menus get Saved in a PROFILE?"
Message 4 of 11
Ranjit_Singh
Yes. Open your cui for your workspace and you should see what it contains.
Message 5 of 11
Yes..but...When I exported that PROFILE.....then imported it into another Machine using the /p switch on the Shortcut.....everything came across...except the Partial Menus
Message 6 of 11
Ranjit_Singh
Are the customizations loaded. Unless they are located on the server, a profile will not pull it up. What does menuload tells you. Does it show all the partial menus loaded?
Message 7 of 11
Yes...the Partial Menus are loaded.....I see them on the screen. I see the Toolbars.....I export the PROFILE (.arg) out to disk.
I launch AutoCAD on another Machine with the /p switch...pointing to that newly created Prolife (.arg) file which I copied to the new machine
AutoCAD opens up....all settings come across.....but the Menu are not loaded.
Message 8 of 11
CSM_MAI
Where are your support files pulling from? Is it possible that the new machine doesn't have the drive mapped for the support file location of the menus?
Message 9 of 11
Ranjit_Singh
OK. Just launch cui (command cui) and then select the relevant workspace and right-click for customize workspace; expand partial customization files. Verify the check boxes with relevant menus are selected. Apply. OK.
Message 10 of 11
All the Support File Paths are local to each machine....and they are there...that is part of the "install/deployment"....The Profile points AutoCAD to those directories....
I think the answer to my initial question is this.....PROFILES do not save Partial Menu settings....
Message 11 of 11
Here is what we are doing...
1. Setup AutoCAD with all our Sysvars, Support File search Paths, menu loaded...etc...
2. Generate a PROFILE from that setup an save it to disk...export it.... (mysetup.arg)
3. Copy all our application files, lsp, mnu, etc.....directories, etc...to each machine
4. Setup that Machines AutoCAD Shortcut....to launch AutoCAD with the /p switch calling our PROFILE.....(mysetup.arg)
When the user launches AutoCAD....ALL of our application specific settings come across....Sysvars, Search paths, etc......EXCEPT the Partial Menus....
