Partial cui ribbon loading
I am trying to create a custom cui in autocad 2013. I created a profile & workspace. I went into the cui & highlighted my workspace & partiality loaded acad.cuix & acetmain.cuix. I go to the customize tab & click on the customize workspace in the right pane. I go to the partially loaded view to add & subtract the ribbon tabs & panels that I want but there are no check boxes. What did I forget to do?
See picture:
Thanks for the reply but the problem is i wasnt getting those green check boxes. There was nothing for me to select
Seems like you need to run a "repair" for AutoCAD
