Block Measurement LISP
Does anyone have a lisp that will measure the distance of two separate blocks some measurement that will stop on the middle of the block ? help please!!!!!
Kent1Cooper
If the Blocks are defined with their insertion points in the middle, you can Object-Snap to those.  Otherwise, Middle-of-2-Points Object Snap may help you, picking opposite sides or corners of each Block in the M2P snap for each Dimension definition point.
Kent Cooper, AIA
