Copy part of drawing placed in PS viewport from one drawing to other drawing
I often need to copy part of drawing placed in PS viewport from one drawing to other drawings
I did it manually by following steps:
  1. First of all in a source drawing from PS I draw outline for viewport, I want to copy to other drawings
  2. UCS – World and From MS I do “copy with base point” 0,0,0
  3. In target drawing I change UCS to World too and do “Paste with original coordinates”
  4. In a source drawing in PS I copy to clipboard viewport..
  5. In target drawing I go to PS and paste saved viewport when I already have in MS necessary part of drawing.My question is: How can I automate this “short” algorithm via lisp
Any help will be appreciated
Here is old code to wblock to a file and another command to insert.
(defun C:WBB (/ NN SS)
(setq NN (strcat "C:/Temp/" (getvar "LOGINNAME")))
(princ (strcat "\nSelect Entities to Write to file [" NN "]."))
(setq SS (ssget))
(if SS
(progn
(if (findfile (strcat NN ".DWG"))
(command "_WBLOCK" NN "Y" "" "0,0,0" SS "")
(command "_WBLOCK" NN "" "0,0,0" SS "")
(if (= (getvar "CMDDIA") 0) (command "N"))
(command "_U")
(princ)
(defun C:INI (/ NN)
(command "_INSERT" (strcat "*" NN) "0,0,0" 1 0)
(princ (strcat "\nError - user drawing [" NN "] NOT Found."))
(princ)
probably I don't undestand somefing, but it not so clear for me how to use this awesome programm in order to copy viewport to other drawing..
load the 2 programs in autocad
in 1st drawing, type WBB, select objects
in 2nd drawing, type INN to insert object
how can I select the viewport in PS and part of drawing within viewport  in MS in one step? Is it possible?
I did some unsuccessful changes in program of MP (http://www.theswamp.org/index.php?action=profile;u=160) in function c:CB  in order to make a selection set from PS and during selection to activate floating MS viewport to continue to make a selection set but program don’t  want to make me happy:) Please check the code and tell me that's wrong...
