Isolate a group of objects through their index number?
Hi everyone,
Could some one tell me how to ISOLATE a group of objects through a list of their index (idxgroup variable in the following code)?
By the way, welcome all advices to improve this code.
Thank you.
My code:
(defun c:test(/ idxgroup)
  (setq obj1 (ssget))
  (command "_.area" "_o" (ssname obj1 0))
  ; area of 1st object
  (setq area (getvar "area"))
  ; pick objects to compare their area values to the 1st one
  (setq obj2 (ssget))
  (setq i (sslength obj2))
  ; loop
  (repeat i
    (setq idx (1- i))
    (command "_.area" "_o" (ssname obj2 idx))
    ; area of the current object
    (setq area2 (getvar "area"))
    (if (= area2 area)
      (progn
	(setq prop (entget (ssname obj2 idx)))
	; change color object
	(setq ed (subst (cons 62 1) (assoc 62 prop) prop))
	(entmod ed)
	 ; object's index group that have equal area
	(setq idxgroup (append idxgroup (list idx)))
	) ; progn
      ) ; if
    (setq i (1- i))
    ) ; repeat
  (command "isolateobjects" <<need helps>>
  ) ; defun
hmsilva
Hi maikhanhmst,
you are creating a list with the index from the second selection set objects with equal area from the first object selected.
Do you need the index in a list to do something else with it?
Or your goal is to isolate all selected objects with the same area, or just the selected in the second ssget function?
Which type of objects you want to select?
Henrique
Hi Henrique,
Thank for your quick response.
My goal is to isolate the objects with the same area. The index do nothing except that. So with the index group I can isolate separately with loop.
hmsilva
If your goal is only to see each object a time, perhaps something like this
(if idxgroup
    (foreach x idxgroup
      (command "isolateobjects" (ssname x obj2) "")
      (command "delay" 2000)
      (command "unisolate")
Hope this helps,
Henrique
Many thanks, Henrique.
It works :).
hmsilva
It works :).
You're welcome, maikhanhmst
Glad I could help
Henrique
