Palette Toggles
Palette Toggles
mikeevans6697
Palette Toggles
mikeevans6697
Like many users I work with two screens. I have my main AutoCAD workspace on one, and palettes on the second. I often need to refer to something outside of AutoCAD (PDF, Email etc) and would like to be able to quickly turn off the display of the palettes on the second screen to see the window below. I am look for the display toggles/variables for the following palettes so I can switch them on and off through a lisp or Macro
TOOLSPACE
PROPERTIES
LAYER PROPERTIES MANAGER
EXTERNAL REFERENCES
So far I have found
PROPERTIES and PROPERTIESCLOSE.
LAYER and LAYERCLOSE
TOOLSPACE will toggle the Toolspace, but no specific command for show or close like the properties.
XREF will show the External References, but not toggle like the TOOLSPACE command.
I would have thought they would all have the same on/off type commands or act the same.
Mike
Shneuph
There is externalreferencesclose.  I don't know about toolspace though.  That's not even showing up in my command search.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
