mline comment
mline comment
mline comment
i need mline comment  lisp,
i like to include trace width in mline comment,
my aim to draw differential pair (double trace) in polyline with equal space.it is directly not possible for me ..so i like to route using mline comment. it is routing (parallel line),it is not a problem,after i can change mline to polyline ..
air cap between two trace should be reduced after change mline to polyline,i like to change(air cap + trace width)include in mline or ml2pl comment.
i include  ML2PL lisp file.
it is any possible  for routing multiple polylines(parallel).
Kent1Cooper
["Cap" should be "gap," and I think what you mean by "comment" would be more appropriately "prompt."]
A quickie, to draw them without going through the middle-man of MLINE [so you can, for instance, include arc segments to round corners].  It asks you to draw the center-line route, and then Offsets that to both sides and removes the initial one.  Without the usual controls, etc.:
(vl-load-com)
(defun C:DTP (/ wid gap offs obj pl); = Double Trace Polyline
  (setq
    wid (getdist "\nTrace width: ")
    gap (getdist "\nAir gap between traces: ")
    offs (/ (+ wid gap) 2)
  ); setq
  (setvar 'plinewid wid)
  (prompt "\nDraw route along center of air gap.")
  (command "_.pline")
  (while (> (getvar 'cmdactive) 0) (command pause))
  (vla-offset (setq obj (vlax-ename->vla-object (setq pl (entlast)))) offs)
  (vla-offset obj (- offs))
  (entdel pl)
  (princ)
); defun
If that does what you want, it could have *error* handling added, prevent invalid inputs, restore the PLINEWID value to what it was before, remember the trace width and gap size and offer them as default values the next time, etc., etc.
Kent Cooper, AIA
This lisp is working well for single time differential pair ,additional something needed in this code.
width-(it is already present in this lisp)
air gap between trace-(this also present in this lisp)
no of times (differential pair needed).
gap between pair to pair (it is for multiple purpose).
Kent1Cooper
That doesn't sound difficult, but post an example image or drawing, showing the "path" you would want the User to draw as a start, and the desired end result.  For example, would the path you draw always be the center-line of the overall group of pairs, no matter how many pairs there are?  If not, what would be the relationship?
Kent Cooper, AIA
Yes.. I want always be centre, for example I give 5,the 5 differential
pair is draw...
