often crashed lisp
often crashed lisp
mruPRQUJ
Message 1 of 26
often crashed lisp
mruPRQUJ
Hello, AutoCAD often crashed when using the attached lisp to modify multiple drawings, especially more than 10 DWGs. I wonder if it can be fixed, thank you very much in advance.
Replies (25)
Message 2 of 26
paullimapa
I'm unable to get it to crash when running on even more than 10 dwgs.
Perhaps it's a graphics or ram memory issue on your end?
The way I've crashed out is when using the file selection gui:
Paul Li
IT Specialist
@The Office
Message 3 of 26
mruPRQUJ
Thank you so much for your kindness and reply. Normally no crashes in the middle stage. If I modify 10 DWGs, it can modify 2 or 3 DWGs, then crashed. I did not do it before at that point. I will test it now, thanks again.
I just tested it at that point, no crashe, many thanks.
Message 4 of 26
paullimapa
FYI: I meant double click the white space during file selection window causes crash for me
Paul Li
IT Specialist
@The Office
Message 5 of 26
mruPRQUJ
Yes, double click white area, windows closed, but AutoCAD did not crash. I tested 5 DWGs, AutoCAD crashed. I am not sure DWG problem or AutoCAD settings. Could you please test these 5 DWGs? Thanks a lot!
Message 6 of 26
paullimapa
no drawings posted
Paul Li
IT Specialist
@The Office
Message 7 of 26
mruPRQUJ
please see attached DWGS,
Message 8 of 26
mruPRQUJ
Next two DWGs
Message 9 of 26
paullimapa
I didn't encounter any crashes running all 5 dwgs testing in both AutoCAD 2020 & 2023.
What AutoCAD version are you running on?
If you have other computers available loaded with AutoCAD, perhaps try the same process on those to see if crash occurs.
Paul Li
IT Specialist
@The Office
Message 10 of 26
mruPRQUJ
I use AutoCAD 2021, maybe my AutoCAD setting has some problems, I just re-installed AutoCAD 2021, Raster Design, and a custom AutoCAD built-in App. Maybe the app caused the problem. How to avoid it? thanks a million.
Message 11 of 26
paullimapa
you can try starting AutoCAD in safemode which will prevent anything from loading at startup:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Paul Li
IT Specialist
@The Office
Message 12 of 26
mruPRQUJ
I will test it later, thank you very much from the bottom of my heart!!!
Message 13 of 26
mruPRQUJ
It works now, thanks a million!
Message 14 of 26
mruPRQUJ
Hi Paul,
It works now, thanks a million. 🙂
Message 15 of 26
paullimapa
Glad to have helped. Cheers!!!
Paul Li
IT Specialist
@The Office
Message 16 of 26
mruPRQUJ
Hi Paul, I just had another post, I am not sure if you are interested in it. It is
"how to avoid to open AutoCAD when using lisp to modify multiple drawings", please see the link below,
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-avoid-to-open-autocad-when-us...
thank you very much in advance!
Message 17 of 26
paullimapa
Since you are experiencing the crash and I’m not, you should read that post and give it a try to see if that helps
Paul Li
IT Specialist
@The Office
Message 18 of 26
mruPRQUJ
It works now and accepted your solutions, thank you very much!
Message 19 of 26
paullimapa
once again glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Message 20 of 26
mruPRQUJ
I am so happy to resolve this issue, I can't thank you enough, much appreciated it. 🙂
