Using ScriptPro app to run AutoCAD lisp for multiple drawings
mruPRQUJ
Message 1 of 10
mruPRQUJ
Hello, could you please advise me on how to use the ScriptPro app to run AutoCAD lisp for multiple drawings? thank you very much in advance.
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
Message 3 of 10
mruPRQUJ
Hello Sir, I am sorry I did not say my question clearly. My question is: Using the ScriptPro app to run AutoCAD lisp for multiple drawings. The script is different with a lisp. I am not looking at how to write a script or edit it, many thanks.
Message 4 of 10
dmfrazier
Message 5 of 10
pendean
Community Legend
Community Legend
SCRIPTPRO app, as the name implies, runs SCRIPTS. You seem to not know your LISP call needs to be in a script file first to use the app that uses scripts to run any commands including scripts.
At that link I shared, after it explains how to do what I just wrote above (since you did not know this), at about a third of the way down... shows you how to exactly use the SCRIPTPRO app
Now you know. Help yourself once more, start over again. If you still wish to use SCRIPTPRO app that requires you to use a script to call the lisp file.
Message 6 of 10
pendean
Community Legend
Community Legend
@dmfrazier wrote:
This is probably the link @pendean  meant to post:
https://www.cad-notes.com/run-a-script-on-multiple-dwg-with-scriptpro/
OP just did not understand that the SCRIPTPRO app requires the creation of a script to run their lisp. Not much else.
Message 7 of 10
mruPRQUJ
Hi Sir, my question should be how to write a script to call a lisp, please provide more detail if it is possible, many thanks.
Message 8 of 10
dmfrazier
Message 9 of 10
mruPRQUJ
Hi, I will try it later as I am tied up right now, thank you very much all of you!
Message 10 of 10
mruPRQUJ
It works, great job! I have another post, would you be interested in it? It is
"how to avoid to open AutoCAD when using lisp to modify multiple drawings", please see the link below,
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-avoid-to-open-autocad-when-us...
thank you very much in advance!
