(defun c:sr2 ( / *error* oOSMODE)
(defun *error* (errmsg)
(if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
(princ (strcat "\nError: " errmsg)))
(if oOSMODE (setvar 'osmode oOSMODE))
(princ))
(setvar "cmdecho" 0)
(setq oOSMODE (getvar 'osmode))
(setvar "osmode" 33)
(PROMPT "\nTHIS PROGRAM IS EXECUTED BY ENG. SAMI SAYED REZK")
(setq fname (getstring "\nEnter File Name To Be saved: "))
(setq fnum (getint "\nEnter Start First Number: "))
(setq txt (open fname "w"))
(setq pt 1)
(while pt
(setq pt (getpoint "Select point: "))
(command "osnap" "none")
(if (/= pt nil) (setq pt1 (polar pt 0.2 0.0)))
(if (/= pt nil) (command "text" pt1 "0.2" "100.0" fnum))
(if (/= pt nil)
(progn (setq nm (itoa fnum))
(setq e (car pt))
(setq n (cadr pt))
(setq n2 (rtos n 2 3))
(setq e2 (rtos e 2 3))(sp)
(setq str (strcat nm n e2 nn n2))
(write-line str txt)
(setq fnum (+ 1 fnum))
(close txt)
(defun c:num (/ *error* oOSMODE rand currnt ptlst )
(princ))
(command "osnap" "end")
(setq rand T )
(setq currnt (getint "\nEnter Start First Number: "))
(setq sc1 (getreal "\nEnter The Drawing Scale: "))
(setq sc (* 1.5 sc1))
(while rand
(setq rand (getpoint "\nSelect Points In Sequence: "))
(setq ptlst
(append ptlst (list rand))))
(mapcar '(lambda (rand) (if rand (progn (setq x (car rand))
(setq y (cadr rand))
(setq rand (list x y ))
(command "text" rand sc "0" currnt)
(setq currnt (+ 1 currnt ))))) ptlst )(princ)(command "osnap" "none")
(defun sp ()
(setq RNM (strlen nm))
(setq RN (strlen n2))
(COND
((= RNM 1) (SETQ N (STRCAT " ")))
((= RNM 2) (SETQ N (STRCAT " " )))
((= RNM 3) (SETQ N (STRCAT " " )))
((= RNM 4) (SETQ N (STRCAT " " )))
(COND
((= RN 1) (SETQ NN (STRCAT " ")))
((= RN 2) (SETQ NN (STRCAT " " )))
((= RN 3) (SETQ NN (STRCAT " " )))
((= RN 4) (SETQ NN (STRCAT " " )))
((= RN 5) (SETQ NN (STRCAT " " )))
((= RN 6) (SETQ NN (STRCAT " " )))
((= RN 7) (SETQ NN (STRCAT " " )))
((= RN 8) (SETQ NN (STRCAT " " )))
((= RN 9) (SETQ NN (STRCAT " " )))
((= RN 10) (SETQ NN (STRCAT " " )))
((= RN 11) (SETQ NN (STRCAT " " )))
((= RN 12) (SETQ NN (STRCAT " " )))
((= RN 13) (SETQ NN (STRCAT " " )))
((= RN 14) (SETQ NN (STRCAT " " )))
(defun num (s)
(if (/= s "Function cancelled") (princ (strcat "\nError: " s)) )
(setq S nil)
(setvar "CMDECHO" ocmd)
(setq *error* olderr)
(princ)
