Object data to text lisp customization request
paliwal222
paliwal222
DEAR ALL
with respect.
requested for customization in lisp file.
by "od2txt" lisp, draw 1 lvl, 1 time, (for next level exit from command and repeat again)
again next all level is overlapped, include 1st level,
can it be modified multiple level in 1 time and not be overlapped.
Thanks.
devitg
Please clear me , what do it mean each text at each ent ?
devitg
 Sorry I have no
ade_odgettables - AutoCAD Map 3D AutoLISP Documentationdevitg_1-1645373217729.png
https://documentation.help › ade_odgettables
An object can have records of more than one table attached. This function lists all the tables that have records attached to the object.
there is not  defun , ade_odgettables
CADaSchtroumpf
With this, you can select many object at one once and select multiple ObjectData (use ctrl + pick in dialog box)
I hope respond to your ask!
(vl-load-com)
(defun str2lst (str sep / pos)
  (if (setq pos (vl-string-search sep str))
    (cons
      (substr str 1 pos)
      (str2lst (substr str (+ (strlen sep) pos 1)) sep)
    (list str)
(defun ListBox (title msg keylab flag / tmp file dcl_id choice)
  (setq
    tmp (vl-filename-mktemp "tmp.dcl")
    file (open tmp "w")
  (write-line
    (strcat "ListBox:dialog{label=\"" title "\";")
    file
  (if (and msg (/= msg ""))
    (write-line (strcat ":text{label=\"" msg "\";}") file)
  (write-line
    (cond
      ((= 0 flag) "spacer;:popup_list{key=\"lst\";")
      ((= 1 flag) "spacer;:list_box{key=\"lst\";")
      (T "spacer;:list_box{key=\"lst\";multiple_select=true;")
    file
  (write-line "}ok_cancel_err;}" file)
  (close file)
  (setq dcl_id (load_dialog tmp))
  (if (not (new_dialog "ListBox" dcl_id))
    (exit)
  (start_list "lst")
  (mapcar 'add_list (mapcar 'cdr keylab))
  (end_list)
  (action_tile
    "accept"
    "(or (= (get_tile \"lst\") \"\")
      (if (= 2 flag)
        (progn
          (foreach n (str2lst (get_tile \"lst\") \" \")
            (setq choice (cons (nth (atoi n) (mapcar 'car keylab)) choice))
          (setq choice (reverse choice))
        (setq choice (nth (atoi (get_tile \"lst\")) (mapcar 'car keylab)))
    (done_dialog)"
  (start_dialog)
  (unload_dialog dcl_id)
  (vl-file-delete tmp)
  choice
(defun c:OD2Label_Side ( / js ename htx AcDoc Space nw_style lst_tabl_def inc_key lst_def desc_od desc_tbl str msg pt deriv rtx nw_obj)
(setq lst_def nil)
  (princ "\nSélectionnez une polyligne.")
  (while
    (null
      (setq js
        (ssget
          (list
            '(0 . "*POLYLINE,LINE,ARC,CIRCLE,ELLIPSE,SPLINE")
            (cons 67 (if (eq (getvar "CVPORT") 1) 1 0))
            (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model"))
    (princ "\nCe n'est pas un objet valable pour cette fonction!")
  (setq
    AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
    Space
    (if (= 1 (getvar "CVPORT"))
      (vla-get-PaperSpace AcDoc)
      (vla-get-ModelSpace AcDoc)
  (cond
    ((null (tblsearch "LAYER" "Label"))
      (vlax-put (vla-add (vla-get-layers AcDoc) "Label") 'color 96)
  (cond
    ((null (tblsearch "STYLE" "Arial-Label"))
      (setq nw_style (vla-add (vla-get-textstyles AcDoc) "Arial-Label"))
      (mapcar
        '(lambda (pr val)
          (vlax-put nw_style pr val)
        (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag)
        (list (strcat (getenv "windir") "\\fonts\\arial.ttf") 0.0 (/ (* 15.0 pi) 180) 1.0 0.0)
  (repeat (setq n (sslength js))
    (setq
      ename (ssname js (setq n (1- n)))
      pt (vlax-curve-getPointAtDist ename (* 0.5 (vlax-curve-getDistAtParam ename (vlax-curve-getEndParam ename))))
      deriv (vlax-curve-getFirstDeriv ename (vlax-curve-GetParamAtPoint ename pt))
      rtx (- (atan (cadr deriv) (car deriv)) (angle '(0 0 0) (getvar "UCSXDIR")))
    (if (or (> rtx (* pi 0.5)) (< rtx (- (* pi 0.5)))) (setq rtx (+ rtx pi)))
    (cond
      ((ade_odgettables ename)
        (if (not htx)
          (progn
            (initget 6)
            (setq htx (getdist (getvar "VIEWCTR") (strcat "\nSpécifiez la hauteur du texte <" (rtos (getvar "TEXTSIZE")) ">: ")))
            (if htx (setvar "TEXTSIZE" htx) (setq htx (getvar "TEXTSIZE")))
        (setq lst_tabl_def (mapcar 'ade_odtabledefn (ade_odgettables ename)) inc_key 0)
        (foreach n lst_tabl_def
          (foreach el n
            (if (listp (cdr el))
              (foreach sel (cdr el)
                (foreach msel sel
                  (if (eq (car msel) "ColName")
                    (setq lst_def (cons (cdr msel) lst_def))
        (if (not desc_od)
          (setq desc_od (listbox "Donnée d'objet" "Choisir des données d'objet" (mapcar 'cons lst_def lst_def) 2) desc_tbl nil)
          (foreach i desc_od
            (if (assoc (cons "ColName" i) (cdaddr n))
              (setq desc_tbl (cons (cdar n) desc_tbl))
        (cond
          (desc_tbl
            (setq
              str
              (apply 'strcat
                (mapcar
                  '(lambda (x y / w)
                    (setq w (ade_odgetfield ename x y 0))
                    (strcat
                      (cond
                        ((eq (type w) 'INT) (itoa w))
                        ((eq (type w) 'REAL) (rtos w 2 2))
                        ((eq (type w) 'STR) w)
                        (T "")
                      "\\P"
                  desc_tbl desc_od
            (setq nw_obj
              (vla-addMtext Space
                (vlax-3d-point (polar '(0.0 0.0 0.0) (* pi 0.5) (getvar "TEXTSIZE")))
                0.0
                str
            (mapcar
              '(lambda (pr val)
                (vlax-put nw_obj pr val)
              (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation)
              (list 4 (getvar "TEXTSIZE") 5 pt "Arial-Label" "Label" rtx)
      (T (princ "\nPas de données d'objet attachées"))
  (prin1)
paliwal222
Dear sir
Dear Bruno
Thank you so much for providing me the lisp.
Its, completely work well, as before many time you help me.
Thanks again form my heart. 😀😀😀  Great.
paliwal222
Dear sir Gabriel
Thank for respond.
