Lisp To AUTOMATICALLY Save And Close All Opened Files
omorah
omorah
MACRO
The below MACRO, I use it when I have lots of drawings opened to change some items in them.
Say I have 5 or 20 sheets opened to change something on each of the sheets.
I added it to my CUIX and added a button for it.
1. Open 5 or 20 or more sheets
2. I would use the CTRL/TAB keys to cycle
through the individual sheets for the edits.
3. ^C^C_purge;all;*;n;zoom;e;qsave;CLOSE;
When done with all the sheets, I would use
this MACRO (button on my personal toolbar),
to close the opened sheets, one by one.
LISP
CloseAllButActive.lsp
This will close all opened files, without zooming and saving, just close all opened files except leave the current file opened. If I have 20 files opened, and am on sheet 5, with this LISP, every other opened file will be closed while sheet 5 (current) will remain opened.
(defun doc:CloseAllButActive (TrueOrFalse / cnt)
(setq cnt 0)
(vlax-for Item (vla-get-Documents (vlax-get-acad-object))
(if (= (vla-get-Active Item) :vlax-False)
(progn
(vla-close Item TrueOrFalse)
(setq cnt (1+ cnt))
cnt
(defun c:cns ( / cnt) ;CLOSES ALL NO SAVE BUT CURRENT ACTIVE
(setq cnt (doc:CloseAllButActive :vlax-False))
(if (> cnt 0)
(princ (strcat "\n(" (itoa cnt) ") document" (if (> cnt 1) "s" "") "
closed without saving."))
(princ "\nNo documents to close.")
(princ)
My ideal goal would be to kinda combine both the MACRO and the LISP to achieve the following.
With say, 20 files opened, edit each file by cycling with the CTRL/TAB, when done with all edits, apply one LISP or MACRO, to do what the above MACRO does, but also automatically save and close the files one by one. That is:
_purge;all;*;n;zoom;e;qsave;CLOSE; then go to the next opened file and do the same all over again.
I thought I had the LISP to do this, but cannot find it. Seen lots of close functions but not exactly what I am looking for. I would really appreciate if anyone would help me. I hope I am clear enough with my needs, with my English here.
Cheers
john.uhden
@omorah
How do want to handle any unnamed (new) docs?
John F. Uhden
hak_vz
Try this
(defun c:savePurgeAndCloseAll ()
	(vlax-for doc (vlax-get (vlax-get-acad-object) 'Documents)
		(cond
			((not (wcmatch  (vlax-get doc 'Name) "Drawing*.dwg"))
				(vla-purgeall doc)
				(vla-save doc)
				(if
					(not
							(vlax-get (vla-get-activeDocument (vlax-get-acad-object)) 'Name)
					(vla-close doc)
	(princ "\nAll files were saved, purged and closed! New drawings need to be named and saved")
	(princ)
Miljenko Hatlak
sander.van.pelt
Hello Hak_vz
I use a lisp file which, after executing multiple commands (purge, audit, xrefs locks + sent to back, lock viewports and zoom extents the model and all layout tabs), saves and closes a drawing.
How should I process my lisp in your lisp so that it performs these actions on all open drawings and then also closes AutoCAD completely.
All drawings that I have open are existing, previously saved drawings. Because of my set variable, AutoCAD does not start automatically with "Drawing 1".
Therefore, previously unsaved drawings will not be saved.
Thank you
