error :Hard error occurred *** internal stack limit reached (simulated)
S_S_SS
S_S_SS
Hello every one
I have an error in a lisp that make a table about blocks and the count of them
it gives me this message
"Select objects: Hard error occurred ***
internal stack limit reached (simulated)"
I Think that it's because I select a huge number of blocks
the count of the blocks is (10000) and i think that error is because that
and thanks in advance......
hak_vz
There can be many reasons that result with stack limit error.
-Check that you don 't have infinite loop in your code,
-that selection set are well written, and that you clear your ssget.
-that your variables are localized
During table rows generation use
(vla-put-RegenerateTableSuppressed tableObject :vlax-true)
Miljenko Hatlak
