numeric Increment along with multileader
ishaq03
Message 1 of 19
ishaq03
Please Provide me lisp where  I can control numeric Increment in Prefix Middle Suffix along with multi leader. For your reference I am attaching the Image file.
Replies (18)
Message 2 of 19
pbejse
The image you posted doesnt tell us much @ishaq03
You mean user is prompt for all three?
Enter prefix:
Enter Middle:
Enter Suffix:
I assume those string values are separated by "-" and suffix is the only one that increments?
Will the user be selecting an existing Mleader and changing the value or create new Mleader for every increment?
Post a sample drawing please.
Message 3 of 19
ishaq03
I assume those string values are separated by "-" and suffix is the only one that increments. Yes I need the Increment in suffix only. and i want to be create new multileader for increment.
Message 4 of 19
pbejse
We need to know if it works on an actual drawing @ishaq03 , the multileader style? the scale? etc..
Again, please post a sample drawing
Message 5 of 19
ishaq03
I attached the sample dwg as you requested.
Message 6 of 19
pbejse
Thanks, that's good.
You have  "TP-RD-Z2-004"  as a value,
  • Enter Prefix string value: TP
  • Enter Middle string value: RD
  • Enter Suffix string value: Z2
Enter Start number: 1 ( and always 3 digits? i.e. 00, 012, 102? )
Then user starts clicking away placing the Mleader
If "TP-RD-Z2" will be the same during increment, why not just
  • Enter string: TP-RD-Z2
  • Enter Start number: 1
Message 7 of 19
ishaq03
Please provide me numerical Increment After TP-RD-Z2
Message 8 of 19
pbejse
So there's only two prompts yes? One for string prefix AND the increment number?  There will be no need to to separate to three prompts. Do you agree?
Message 9 of 19
ishaq03
yes agreed.
Message 10 of 19
pbejse
Here's a simple code
(defun c:IncAt ( / _padzeros Prefix startNos p1 p2)
(defun _padzeros ( s l)
	(if (< (strlen s) l) (_padzeros (strcat "0" s) l) s))
      (if
            (and
                  (setq Prefix (getstring "\nEnter Prefix string value: " ))
                  (setq startNos (getint "\nEnter Start number: "))
            (while (and
                        (setq p1 (getpoint "\nPick target point"))
			(setq p2 (getpoint p1 "\nText Location"))
                  (command "_Mleader" "_non" (trans p1 1 0) "_non" (trans p2 1 0) "")
                  (vla-put-textstring (vlax-ename->vla-object (entlast))
                        	(strcat Prefix "-" (_padzeros (itoa startNos) 3)))
                  (setq startNos (1+ startNos)))
      (princ)
Command: Incat
Let me know how it goes.
Message 11 of 19
ishaq03
Thanks Patrick Evangelista it's working perfectly as per my requirement.
Message 12 of 19
pbejse
Anytime @ishaq03 [(whispering) listen we dont use  names here  😁 ]
Message 13 of 19
k.rakha
@pbejse It worked perfectly, but can be edited to include the text inside a circle block?
Message 14 of 19
Jafarali
Community Visitor
Community Visitor
how to use this lisp i need the same
I am new in lisp tools, can you help me
loded lisp tool and what is the commend for this list to active
Message 15 of 19
pbejse
  • Copy the code at post # 15
  • Save the file as INCAT.lsp
  • Load the file using Appload.
Command: INCAT
Enter Prefix string value: BANANA
Enter Start number: 456
Pick target point
Text Location
Of course it depends on the current multileader style.
Message 16 of 19
pbejse
(defun c:IncAt ( / _padzeros Prefix startNos p1 p2 ml attblock firstAtt BlockIDcoll)
      (if
            (and
            (while (and
                  (setq ml (vlax-ename->vla-object (entlast)))
                  (setq nstr (strcat Prefix "-" (_padzeros (itoa startNos) 3)))
                  (cond
                        ((snvalid  (setq attblock  (vla-get-ContentBlockName ml)))
                          (setq mblk (vla-item (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object))) attblock))
                         (or firstAtt
                             (progn
                         	(vlax-for itm mblk (setq BlockIDcoll (cons itm BlockIDcoll)))
                                (vl-some '(lambda (o)(and (eq (vla-get-ObjectName o) "AcDbAttributeDefinition")
                                                             (setq firstAtt (vla-get-ObjectID o))))
                                                     BlockIDcoll )
                         (vla-SetBlockAttributeValue ml firstAtt nstr)
                  	((vla-put-textstring ml  nstr))
      (princ)
Message 17 of 19
ishaq03
Dear Pbejse,
can we add Northing Easting Coordinates below the numbering via use the Insert field Formula, Means when Multileader pick point taken first row should be a numerical increment then below dynamically coordinates labels.
For your reference I am attaching a video Please check and give me your response as soon as possible.
Message 18 of 19
sooryaprabha9393
Community Visitor
Community Visitor
Can you add a provision for giving suffix also after the numer?
Message 19 of 19
pijus_s
Community Visitor
Community Visitor
Thank you for your work @pbejse
