Adding attributes to hundreds of blocks
Designer_1E
Designer_1E
(I posted this previously in the wrong forum ‌😬‌)
I need to add the same 7 invisible attributes to hundreds of different blocks, within one drawing. Ideally they would be added to the base point. I am searching for an autoLISP that can do this. Any recommendations?
I have attached a file with the attributes in needed, if you are curious.
paullimapa
Questions:
1) In which dwg are these hundreds of blocks located?
2) What are the names of these blocks?
3) Are the blocks dynamic?
4) Can you share a sample dwg with these blocks?
Paul Li
IT Specialist
@The Office
Sea-Haven
There is sample code for add an attribute to an existing block definition. Do a google. Like @paullimapa where is the list of block names for the attributes to be added to and need a dwg to test.
komondormrex
@Designer_1E
hey there,
check the following. adds 7 given attributes to every block in a drawing with syncing.
(defun c:add_atts nil
  (vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
  (setvar 'cmdecho 0)
  (vlax-map-collection (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    '(lambda (block)
      (and (zerop (vlax-get block 'islayout))
         (zerop (vlax-get block 'isxref))
         (mapcar '(lambda (prompt tag)
              (vla-addattribute block
                        0.001
                        acAttributeModeInvisible
                        prompt
                        (vlax-3d-point 0 0 0)
                        tag
              t
             '("Person"    "Department" "Floor"    "Building" "Alias 1"   "Alias 2"   "Alias 3")
             '("CAPPERSON" "CAPDEPT"    "CAPFLOOR" "CAPBLDG"  "CAPALIAS1" "CAPALIAS2" "CAPALIAS3")
         (command "_attsync" "_n" (vla-get-name block))
  (setvar 'cmdecho 1)
  (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  (princ)
