no function definition: INITERR
I have searched all over and can't find a solution to this.
I am loading a lisp routine in AutoCAD 2013.  The lisp was created several years ago, before 2013. The lisp routine appears to be loading successfully, but when I try to run it, I get this error message:
I have a friend with 2014 who is able to run the identical lisp routine with no problem.
Please help!
Thank you.
kerry_w_brown
I assume INITERR is a purpose written function to save the values of variables prior to running an application that makes temporary changes to those variables..
There will probably be a function to RESET the variable values as well.
Here's a sample
http://www.afralisp.net/autolisp/tutorials/error-trapping.php
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
stevor
The 'purpose lisp' is likely,
so search on your friends' systems,
and your own, for the string
 defun INITERR, or (INITERR
and see what you got.
S
