Need to copy excel table to AutoCAD drawing using AutoLISP
santvn
Observer
santvn
Observer
Observer
Hi, I'm working on Automation of copying tables from *.csv files to AutoCAD drawing and placing them with the some scaling. This can achievable through AutoLISP? I found PASTE SPECIAL command to import excel tables as editable tables, Is it possible to Automate this process using AutoLISP?
Replies (14)
Sea-Haven
If you google you will find read csv to table lots of examples, the result may need some custom setting or you need to make a table style before running, in simple terms read all the csv lines to work out the number of columns or ask. Then just read all lines and populate a table.
I have something but it was written for a particular CSV ie 5 columns. You want a more global answer. By the time I amend some else will already have it.
santvn
Observer
Observer
Hi Sea - Heaven,
Thanks for your reply.
I'm new to AutoLISP coding, can you please help me with a small code as example?
Santhosh
Sea-Haven
For me I would be going direct read from excel not csv, I have a read a range code from excel so would use that then the routine is global for any excel row/column. Will look into a ALL option A1 -> last cell. I know from other stuff I have done sounds simple but when setting column width have to check number of characters like "A" v's "ABCDEFGHIJK" so column has to be made wider.
Need a sample xls to have a play with.
pbejse
as Editable tables meaning OLE or just plain ACAD_Table?
Sea-Haven
There is another post out there where paste special was discussed at length and I think the end answer was No. Will see if can find. The use of vla-send was discussed if I remember right.
santvn
Observer
Observer
As a ACAD Table. I need to automate the PASTE Special functionality using AutoLIST. Is that possible?
pbejse
I take it you have the excel file opened for you to copy just random bits and parts of the spreadsheet, then you are better off using copy and paste.
If you want the entire table or specific range or tab then yes, certainly doable with Autolisp.
Sea-Haven
I have started on something, done the get all based on the great code of getexcel.lsp. Returns max row and column so next step is pick point for table. Just need some time. I have the make table code already. For moment will base it on cell A1 is Title, row 2 is headings, row 3 + is data.
I have a very complex excel to test with so will be interesting.
john.uhden
@santvn
I think @pbejse gave you a direct hit.
In Excel grab the range of cells that you want, then Ctrl+C (copy),
then in AutoCAD Ctrl+V (paste).
It will come in as an OLE which you can edit and resize and move wherever you want.
John F. Uhden
calderg1000
Regards @santvn
What kind of data do you have in your CSV file, can you give us an image...?
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
hak_vz
Start command TABLE from ribbon, command line or however you like it.
In table dialog from Insert options select "From a data link", click on "Data Link Manager" icon, in DLM select "Create new data link", give it some name let say "CSV_1", and select your CSV file (change default file extension from .xlsx to .csv).
Pick a point where you want to place your table and that's it.
Cells in table are initially in locked state, but simply select all cells, right click, locking and select Unlock.
To make data in table undependable to data in linked CSV file select table, right click and in Data link sub-menu select "Detach Data link" and answer "Yes" to follow up dialog.
Investigate other options available with table manager.
This can be done with lisp for simple csv files but for particular table case and is actually not usable for various table options you may have in your csv or Excel.
Miljenko Hatlak
calderg1000
Regards @santvn
Try this code, to import CSV files to ACAD table...
By default it looks for the file in the Documents folder. If it is not there, you can address it.
(vl-load-com)
(defun c:T_Csv (/ adoc spm tt pt1 ncolumns rowheight colwidth objtable ls lv ln
                lt s en tx f fline data
  (setq adoc (vla-get-activedocument (vlax-get-acad-object))
        spm  (vla-get-modelspace adoc)
  (if (and
        (setq f (getfiled "Select csv file to import data" "" "csv" 4))
        (setq f (open f "r"))
    (progn
      (setq tt        "CSV FILE DATA TABLE"
            pt1       (vlax-3d-point
                        (getpoint "\nPick the top left point to insert the table: ")
            nrows     2
            ncolumns  2
            rowheight 5
            colwidth  20
      (setq objtable (vla-addtable spm pt1 nrows ncolumns rowheight colwidth))
      (setq item 1)
      (vla-settext objtable 0 0 tt)
      (vla-settext objtable 1 0 "Item")
      (vla-settext objtable 1 1 "Value")
      (vla-SetTextHeight Objtable (+ acDataRow acHeaderRow acTitleRow) 1.5)
      (setq objtable (vlax-ename->vla-object (entlast)))
      (while
        (setq fline (read-line f))
         (if (/= fline "")
           (progn
             (setq tx   item
                   data fline
             (vla-InsertRows objtable nrows 3.0 1)
             (vla-SetTextHeight Objtable (+ acDataRow) 1.0)
             (vla-SetAlignment Objtable acDataRow acMiddleCenter)
             (vla-settext objtable nrows 0 tx)
             (vla-settext objtable nrows 1 data)
             (setq nrows (+ nrows 1))
           (alert "End Rows...")
         )                                        ;if
         (setq item (1+ item))
      )                                           ;While
    )                                             ;if
  (close file)
  (vlax-release-object objtable)
  (princ)
Carlos Calderon G
hak_vz
@calderg1000
Use your code to import following CSV data, and see what's wrong.
Items count;;
No;Name;Total
1;A;21
2;B;22
3;C;23
4;D;45
5;E;36
;Total sum:;147
Code has to be written for general case, where number of rows a columns is unknown, without defining titles and headers.
Miljenko Hatlak
Sea-Haven
"Code has to be written for general case, where number of rows a columns is unknown"
Ok finally got something working. Would appreciate any comments.
Proceedure is have excel open, A1 is title, row 2 is header details, row 3+ is data
; https; //forums.autodesk.com/t5/visual-lisp-autolisp-and-general/need-to-copy-excel-table-to-autocad-drawing-using-autolisp/td-p/11334140;;
; read all cells of excel and make a Acad table
; By AlanH AUG 2022
; Expects a title in A1
; Expects row 2 is header info
; row 3+ is data
(defun AHMaketable (numcolumns / colwidth numcolumns numrows objtable rowheight sp vgad vgao vgms)
(vl-load-com)
(setq sp (vlax-3d-point (getpoint "\nPick point for table")))
(Setq vgms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(setq numrows 3)
(setq rowheight 2.5) get current style height
(setq colwidth 60) width later
(setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth))
(command "_zoom" "e")
(princ)
; Program Name: GetExcel.lsp [GetExcel R7]
; Created By:   Terry Miller (Email: terrycadd@yahoo.com)
;               (URL: https://autolisp-exchange.com)
; Date Created: 9-20-03
(defun getallcells ( /  row# Column# Range$ ExcelRange^ ExcelVariant^ ExcelValue Data@)
      (setq CurRegion (vlax-get-property (vlax-get-property
        (vlax-get-property  myxl "ActiveSheet") "Range" "A1") "CurrentRegion")
      (setq MaxRow# (vlax-get-property (vlax-get-property CurRegion "Rows") "Count"))
      (setq MaxColumn# (vlax-get-property (vlax-get-property CurRegion "Columns") "Count"))
   (setq *ExcelData@ nil)
  (setq Row# 1)
  (repeat MaxRow#
    (setq Data@ nil)
    (setq Column# 1)
    (repeat MaxColumn#
      (setq Range$ (strcat (Number2Alpha Column#)(itoa Row#)))
      (setq ExcelRange^ (vlax-get-property myxl "Range" Range$))
      (setq ExcelVariant^ (vlax-get-property ExcelRange^ 'Value))
      (setq ExcelValue (vlax-variant-value ExcelVariant^))
      (setq ExcelValue
        (cond
          ((= (type ExcelValue) 'INT) (itoa ExcelValue))
          ((= (type ExcelValue) 'REAL) (rtosr ExcelValue))
          ((= (type ExcelValue) 'STR) (vl-string-trim " " ExcelValue))
          ((/= (type ExcelValue) 'STR) "")
      (setq Data@ (append Data@ (list ExcelValue)))
      (setq Column# (1+ Column#))
    (setq *ExcelData@ (append *ExcelData@ (list Data@)))
    (setq Row# (1+ Row#))
(princ)
; Number2Alpha - Converts Number into Alpha string
; Function By: Gilles Chanteau from Marseille, France
; Arguments: 1
;   Num# = Number to convert
; Syntax example: (Number2Alpha 731) = "ABC"
(defun Number2Alpha (Num# / Val#)
  (if (< Num# 27)
    (chr (+ 64 Num#))
    (if (= 0 (setq Val# (rem Num# 26)))
      (strcat (Number2Alpha (1- (/ Num# 26))) "Z")
      (strcat (Number2Alpha (/ Num# 26)) (chr (+ 64 Val#)))
);defun Number2Alpha
; rtosr - Used to change a real number into a short real number string
; stripping off all trailing 0's.
; Arguments: 1
;   RealNum~ = Real number to convert to a short string real number
; Returns: ShortReal$ the short string real number value of the real number.
(defun rtosr (RealNum~ / DimZin# ShortReal$)
  (setq DimZin# (getvar "DIMZIN"))
  (setvar "DIMZIN" 8)
  (setq ShortReal$ (rtos RealNum~ 2 8))
  (setvar "DIMZIN" DimZin#)
  ShortReal$
);defun rtosr
; Starts here
(defun ahgetallexcel2table ( / myxl objtable l2 x y val numrows *ExcelData@  Maxcolumn)
(or (setq myxl (vlax-get-object "Excel.Application"))
    (setq myxl (vlax-get-or-create-object "excel.Application"))
(vla-put-visible myXL :vlax-true)
(vlax-put-property myxl 'ScreenUpdating :vlax-true)
(vlax-put-property myXL 'DisplayAlerts :vlax-true)
(getallcells)
(AHMaketable MaxColumn#)
(vla-settext objtable 0 0 (car  (nth 0 *ExcelData@ )))
(setq l2 (nth 1 *ExcelData@))
(setq y 0)
(foreach val l2
  (vla-settext objtable 1 y val)
  (setq Y (1+ Y))
(vla-put-regeneratetablesuppressed Objtable :vlax-true) ; speeds up process.
(setq numrows 2)
(repeat (- (length *ExcelData@) 2)
  (setq data (nth numrows *ExcelData@))
  (setq cols -1 )
  (repeat MaxColumn#
    (vla-settext objtable numrows (setq cols (1+ cols)) (nth cols data))
  (setq numrows (1+ numrows))
  (vla-InsertRows Objtable  numrows (vla-GetRowHeight Objtable  1) 1)
(vla-put-regeneratetablesuppressed Objtable :vlax-false)
(princ)
(ahgetallexcel2table)
