Need Lisp to draw the grid and coordinates of the map sheet
Oliver_C3D
Message 1 of 22
Oliver_C3D
Hello Dears
I need a lisp grid and draw the coordinates of the map sheet in the image format below.
Thank you for your attention
Replies (21)
Message 21 of 22
gxz1135261742
Observer
Observer
Thank you in advance. I add the (setq ang (+ ang pi)) as shown, but does not work in some quadrants, do you have any suggestions?
Message 22 of 22
Sea-Haven
I know it took me a while to get the text working away from the box. So I have other projects more urgent sorry. Just change a little bit at a time in a copy of the lsip. Look at the "ah:dotext1 2 &  3" defuns. Change 1 at a time to see what happens. Set a UNDO mark before running then can undo back to that running point.
