Need LISP to add new layers to existing saved Named Views
jorgearone_inssitu
jorgearone_inssitu
hello everyone
I have a problem that suddenly can be solved with a lisp
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/need-lisp-to-add-new-layers-to-exist...
I have an Architecture base and created saved views,
but as I add layers (because that is usually my work routine)
When I change views, all the layers created after the views were created are frozen.
I think even LAYER STATES have the same characteristic.
I would like to see if it is possible that there is a lisp that updates all the saved views (with all the current layers)
[ The subject line of this post has been edited for clarity by @pendean Original: Updates Saved Views]
Kent1Cooper
@jorgearone_inssitu wrote:
... as I add layers .... When I change views, all the layers created after the views were created are frozen. ....
That sounds like exactly what is supposed to happen when you add Layers using this icon in the Layer Manager:
Is that how you are adding them?  If you use the one to the left of that, the added Layer will be visible in all Viewports.
Kent Cooper, AIA
jorgearone_inssitu
no, I have been using this option. I have checked again.
pendean
Community Legend
Community Legend
...When I change views, all the layers created after the views were created are frozen....
Explain your process very precisely please so someone over here can follow along: "views" can mean many things and in many places in a DWG file.
.... a lisp that updates all the saved views...
updates what please? be detailed, you may be using too generic a term when we need specifics to follow along.
... (with all the current layers)...
...no, I have been using this option. I have checked again....
What "all" do you mean please? again, we want to follow along more precisely.
TIA
jorgearone_inssitu
Ok, I have saved views
I have a problem that suddenly can be solved with a lisp.
When I create the views, I keep creating layers (that's my workflow) and work with them (they are not turned off or frozen), but when I change views, the layers disappear, as you can see, the layers created after creating the views views are frozen (when changing views)
ВeekeeCZ
So why don't you save the views WITHOUT layer snapshot
jorgearone_inssitu
Thank you very much, I did not know that option.
Yes indeed that is the solution. Thank you very much again.
