Minor changes to one existing lisp
mruPRQUJ
Message 1 of 21
mruPRQUJ
I wonder if some minor changes can be added to the below lisp, thank you very much in advance.
1. freeze layer "$X-ANNO-REVC"
2. delete all objects "REVCLOUD"
The lisp is below, it was attached as well,
(vl-load-com)
(defun c:ASet (/ format_date chgtxt adoc data_assoc_list ss attribute_tag attribute_string)
(defun format_date (/ mon date)
(setq mon '("JAN" "FEB" "MAR" "APR" "MAY" "JUN" "JUL" "AUG" "SEP" "OCT" "NOV" "DEC"))
(setq date (rtos (fix (getvar "cdate")) 2 0))
(strcat (substr date 1 4) (nth (1- (atoi (substr date 5 2))) mon) (substr date 7 2))
(defun chgtxt (string)
(cond
(= (car (reverse (vl-string->list string))) 65)
(vl-string-subst "" "A" string)
(= (car (reverse (vl-string->list string))) 97)
(vl-string-subst "" "a" string)
(setq data_assoc_list '(
("DATE" . "2023JUL30")
(if (ssget "_X" (list '(0 . "insert")))
(vlax-for block_reference (vla-get-activeSelectionSet (vla-get-activedocument (vlax-get-acad-object)))
(cond
(wcmatch (strcase (vla-get-effectiveName block_reference)) "BCH-X-BORD-DXXX,BCH-X-BORD-BXXX,BCH-X-BORD-AXXX,BCH-X-BORD-REVI,BCH-X-BORD-REVI-TRIA,BCH-X-ANNO-STMP-OBSO")
(foreach attribute (vlax-invoke block_reference 'getAttributes)
(setq attribute_tag (strcase (vla-get-tagString attribute)))
(setq attribute_string (vla-get-textString attribute))
(cond
(setq item (assoc attribute_tag data_assoc_list))
  (vla-put-textString attribute (format_date))
  (vla-put-textString attribute (cdr item))
(wcmatch attribute_tag "REV_`#,R_NO,R_NO_D&E,R_NO_A&B,REV_NO")
      (cond
       ((wcmatch attribute_string "#[AaAa]")
        (setq attribute_string (substr attribute_string 1 1)) ; keep only #
        (vla-put-textString attribute attribute_string)
       ((wcmatch attribute_string "##[AaAa]")
        (setq attribute_string (substr attribute_string 1 2))  ; keep only ##
      ) ; cond
(= "BCH-ST-DYN-DWG-ISSUE" (vla-get-effectivename block_reference))
(setpropertyvalue (vlax-vla-object->ename block_reference) "AcDbDynBlockPropertyVisibility" "IFC - ISSUE FOR CONSTRUCTION")
t
(vlax-release-object block_reference)
(princ)
Replies (20)
Message 2 of 21
paullimapa
just replace the (princ) at the end of the code with the following:
 (vl-cmdf "_.Layer" "_F" "$X-ANNO-REVC" "") ; freeze layer "$X-ANNO-REVC"
 (if(setq ss(ssget"_X"'((8 . "REVCLOUD")))) ; delete all objects "REVCLOUD"
  (progn
   (vl-cmdf "_.Layer" "_U" "REVCLOUD" ""); make sure layer is unlocked
   (foreach item (mapcar 'cadr (ssnamex ss))  ; create list of all entities from selection set
    (if (= 'ename (type item))(entdel item)) ; confirm is entity & delete
   ) ; foreach
  ) ; progn
 ) ; if
(princ)
Paul Li
IT Specialist
@The Office
Message 3 of 21
mruPRQUJ
thank you very much for your quick response. I will test it tomorrow. I wonder if you can provide another option,
1. only freeze the layer
2. only delete the objects
They can be used in different scenarios,
thanks again 🙂
Message 4 of 21
paullimapa
that's simple.
if you only want to freeze the layer, then just include this:
 (princ)
if you only what to delete the objects then just include this:
  (progn
   ) ; foreach
  ) ; progn
 ) ; if
 (princ)
Paul Li
IT Specialist
@The Office
Message 5 of 21
mruPRQUJ
It is late today, I will test tomorrow, thank you very much from the bottom of my heart. 😀
Message 6 of 21
mruPRQUJ
1. "Freeze layer" works perfectly.
2. "Delete objects Revcloud" did not work, I may make a mistake, many thanks.
Message 7 of 21
paullimapa
share your dwg that has objects on Layer REVCLOUD that needs to be deleted for me to test
Paul Li
IT Specialist
@The Office
Message 8 of 21
mruPRQUJ
Sorry, I did not say it clearly in the beginning. The objects are REVCLOUD, not on the layer REVCLOUD, could be on any layer, thanks.
Message 9 of 21
paullimapa
so most likely they're just plines which will make it very difficult to filter out from other plines.
in future remind everyone to place them on unique layer so that can be easily filtered out for erasing
Paul Li
IT Specialist
@The Office
Message 10 of 21
mruPRQUJ
The objects type is revcloud, please see the image below, thanks
Message 11 of 21
paullimapa
Again share dwg with this object
Paul Li
IT Specialist
@The Office
Message 12 of 21
mruPRQUJ
sorry about it, please see attached file, thanks.
Message 13 of 21
paullimapa
just a polyline so nothing special
Paul Li
IT Specialist
@The Office
Message 14 of 21
mruPRQUJ
It is weird, I opened with AutoCAD 2021 & 2023, Both of them show revcloud, please see the image below. I use AutoCAD qselect command, also select revcloud object. Could you please consider it as object type "revcloud"? thanks.
Message 15 of 21
hmsilva
@mruPRQUJ
to select all revclouds
(ssget "X" '((-3 ("RevcloudProps"))))
Hope this helps,
Henrique
Message 16 of 21
paullimapa
based on @hmsilva excellent response:
 (if(setq ss(ssget "X" '((-3 ("RevcloudProps"))))) ; delete all objects "REVCLOUD"
   ) ; foreach
 ) ; if
 (princ)
this assumes all layers are unlocked for the REVCLOUD to be deleted
Paul Li
IT Specialist
@The Office
Message 17 of 21
mruPRQUJ
thanks a lot! 🙂
Message 18 of 21
hmsilva
@mruPRQUJ wrote:
thanks a lot! 🙂
You're welcome, @mruPRQUJ
Glad I could help
Henrique
Message 19 of 21
mruPRQUJ
Great job! It works very well. Thanks a million. 🙂
Message 20 of 21
paullimapa
Sure but definitely needed @hmsilva input on that one
Paul Li
IT Specialist
@The Office
