I took some time to modify CAB's code and added GrSnap, so that insertion of blocks is performed precisely...
Here is my version...
;; This is a kludge of a routine that will allow rotation via the L fo CCW and R for CW
;; rotation while moving the block. If you are through rotating and want the osnap to
;; work press shift+right click to make another setting then currently set 'osmode'.
(defun c:ins+rot_L-R+osnap ( / LM:acapp *error* GrSnap-subs cmd ape osm pdm bname loop key ll grr ip lastpt ent ch )
;; Application Object - Lee Mac
;; Returns the VLA Application Object
;; Mod. by M.R.
(defun LM:acapp nil
(eval
(list 'defun 'LM:acapp '( / cad )
(if (vl-catch-all-error-p (setq cad (vl-catch-all-apply (function vlax-get-acad-object) nil)))
(progn (vl-load-com) (vlax-get-acad-object))
cad
(LM:acapp)
(defun *error* ( m )
(if ll
(progn
(foreach x ll
(setq x nil)
(setq ll nil)
(if command-s
(command-s "_.undo" "_end")
(vl-cmdf "_.undo" "_end")
(if cmd (setvar (quote cmdecho) cmd))
(if ape (setvar (quote aperture) ape))
(if osm (setvar (quote osmode) osm))
(if pdm (setvar (quote pdmode) pdm))
(if doc (vla-regen doc acactiveviewport))
(if m (prompt m))
(princ)
(defun GrSnap-subs nil
(eval
(progn
;; Object Snap for grread: Snap Function - Lee Mac
;; Returns: [fun] A function requiring two arguments:
;; p - [lst] UCS Point to be snapped
;; o - [int] Object Snap bit code
;; The returned function returns either the snapped point (displaying an appropriate snap symbol)
;; or the supplied point if the snap failed for the given Object Snap bit code.
(defun LM:grsnap:snapfunction ( )
(eval
(list 'lambda '( p o / q )
(list 'if '(zerop (logand 16384 o))
(list 'if
'(setq q
(cdar
(vl-sort
(vl-remove-if 'null
(mapcar
(function
(lambda ( a / b )
(if (and (= (car a) (logand (car a) o)) (setq b (osnap p (cdr a))))
(list (distance p b) b (car a))
(0001 . "_end")
(0002 . "_mid")
(0004 . "_cen")
(0008 . "_nod")
(0016 . "_qua")
(0032 . "_int")
(0064 . "_ins")
(0128 . "_per")
(0256 . "_tan")
(0512 . "_nea")
(2048 . "_app")
(8192 . "_par")
(function (lambda ( a b ) (< (car a) (car b))))
(list 'LM:grsnap:displaysnap '(car q)
(list 'cdr
(list 'assoc '(cadr q)
(list 'quote
(LM:grsnap:snapsymbols
(atoi (cond ((getenv "AutoSnapSize")) ("5")))
(LM:OLE->ACI
(if (= 1 (getvar 'cvport))
(atoi (cond ((getenv "Layout AutoSnap Color")) ("117761")))
(atoi (cond ((getenv "Model AutoSnap Color")) ("104193")))
'(cond ((car q)) (p))
;; Object Snap for grread: Display Snap - Lee Mac
;; pnt - [lst] UCS point at which to display the symbol
;; lst - [lst] grvecs vector list
;; col - [int] ACI colour for displayed symbol
;; Returns nil
(defun LM:grsnap:displaysnap ( pnt lst col / scl )
(setq scl (/ (getvar 'viewsize) (cadr (getvar 'screensize))))
(setq pnt (trans pnt 1 1))
(grvecs (cons col (mapcar (function (lambda ( x ) (mapcar (function +) (mapcar (function *) x (list scl scl)) pnt))) lst))
(list
(list 1.0 0.0 0.0 0.0)
(list 0.0 1.0 0.0 0.0)
(list 0.0 0.0 1.0 0.0)
(list 0.0 0.0 0.0 1.0)
) ;;; This matrix is for presentation of vectors - start/end points should be supplied in DCS ; if you omit matrix - start/end points should be supplied in UCS
;; Object Snap for grread: Snap Symbols - Lee Mac
;; p - [int] Size of snap symbol in pixels
;; Returns: [lst] List of vector lists describing each Object Snap symbol
(defun LM:grsnap:snapsymbols ( p / -p -q -r a c i l q r )
(setq -p (- p) q (1+ p)
-q (- q) r (+ 2 p)
-r (- r) i (/ pi 6)
a 0.0
(repeat 12
(setq l (cons (list (* r (cos a)) (* r (sin a))) l)
a (- a i)
(setq c (apply 'append (mapcar 'list (cons (last l) l) l)))
(list
(list 0001
(list -p -p) (list p -p) (list p -p) (list p p) (list p p) (list -p p) (list -p p) (list -p -p)
(list -q -q) (list q -q) (list q -q) (list q q) (list q q) (list -q q) (list -q q) (list -q -q)
(list 0002
(list -r -q) (list 0 r) (list 0 r) (list r -q)
(list -p -p) (list p -p) (list p -p) (list 0 p) (list 0 p) (list -p -p)
(list -q -q) (list q -q) (list q -q) (list 0 q) (list 0 q) (list -q -q)
(cons 0004 c)
(vl-list* 0008 (list -r -r) (list r r) (list r -r) (list -r r) c)
(list 0016
(list p 0) (list 0 p) (list 0 p) (list -p 0) (list -p 0) (list 0 -p) (list 0 -p) (list p 0)
(list q 0) (list 0 q) (list 0 q) (list -q 0) (list -q 0) (list 0 -q) (list 0 -q) (list q 0)
(list r 0) (list 0 r) (list 0 r) (list -r 0) (list -r 0) (list 0 -r) (list 0 -r) (list r 0)
(list 0032
(list r r) (list -r -r) (list r q) (list -q -r) (list q r) (list -r -q)
(list -r r) (list r -r) (list -q r) (list r -q) (list -r q) (list q -r)
(list 0064
'( 0 1) (list 0 p) (list 0 p) (list -p p) (list -p p) (list -p -1) (list -p -1) '( 0 -1)
'( 0 -1) (list 0 -p) (list 0 -p) (list p -p) (list p -p) (list p 1) (list p 1) '( 0 1)
'( 1 2) (list 1 q) (list 1 q) (list -q q) (list -q q) (list -q -2) (list -q -2) '(-1 -2)
'(-1 -2) (list -1 -q) (list -1 -q) (list q -q) (list q -q) (list q 2) (list q 2) '( 1 2)
(list 0128
(list (1+ -p) 0) '(0 0) '(0 0) (list 0 (1+ -p))
(list (1+ -p) 1) '(1 1) '(1 1) (list 1 (1+ -p))
(list -p q) (list -p -p) (list -p -p) (list q -p)
(list -q q) (list -q -q) (list -q -q) (list q -q)
(vl-list* 256 (list -r r) (list r r) (list -r (1+ r)) (list r (1+ r)) c)
(list 0512
(list -p -p) (list p -p) (list -p p) (list p p) (list -q -q) (list q -q)
(list q -q) (list -q q) (list -q q) (list q q) (list q q) (list -q -q)
(list 2048
(list -p -p) (list p p) (list -p p) (list p -p)
(list (+ p 05) -p) (list (+ p 06) -p) (list (+ p 05) -q) (list (+ p 06) -q)
(list (+ p 09) -p) (list (+ p 10) -p) (list (+ p 09) -q) (list (+ p 10) -q)
(list (+ p 13) -p) (list (+ p 14) -p) (list (+ p 13) -q) (list (+ p 14) -q)
(list 8192 (list r 1) (list -r -q) (list r 0) (list -r -r) (list r q) (list -r -1) (list r r) (list -r 0))
;; Object Snap for grread: Parse Point - Lee Mac
;; bpt - [lst] Basepoint for relative point input, e.g. @5,5
;; str - [str] String representing point input
;; Returns: [lst] Point represented by the given string, else nil
(defun LM:grsnap:parsepoint ( bpt str / str->lst lst )
(defun str->lst ( str / pos )
(if (setq pos (vl-string-position 44 str))
(cons (substr str 1 pos) (str->lst (substr str (+ pos 2))))
(list str)
(if (wcmatch str "`@*")
(setq str (substr str 2))
(setq bpt (list 0.0 0.0 0.0))
(if
(and
(setq lst (mapcar (function distof) (str->lst str)))
(vl-every (function numberp) lst)
(< 1 (length lst) 4)
(mapcar (function +) bpt lst)
;; Object Snap for grread: Snap Mode - Lee Mac
;; str - [str] Object Snap modifier
;; Returns: [int] Object Snap bit code for the given modifier, else nil
(defun LM:grsnap:snapmode ( str )
(vl-some
(function
(lambda ( x )
(if (wcmatch (car x) (strcat (strcase str t) "*"))
(progn (setq ff t) (princ (cadr x)) (caddr x))
("endpoint" " of " 0001)
("midpoint" " of " 0002)
("center" " of " 0004)
("node" " of " 0008)
("quadrant" " of " 0016)
("intersection" " of " 0032)
("insert" " of " 0064)
("perpendicular" " to " 0128)
("tangent" " to " 0256)
("nearest" " to " 0512)
("appint" " of " 2048)
("parallel" " to " 8192)
("none" "" 16384)
;; OLE -> ACI - Lee Mac
;; Args: c - [int] OLE Colour
(defun LM:OLE->ACI ( c )
(apply (function LM:RGB->ACI) (LM:OLE->RGB c))
;; OLE -> RGB - Lee Mac
(defun LM:OLE->RGB ( c )
(mapcar (function (lambda ( x ) (lsh (lsh (fix c) x) -24))) (list 24 16 8))
;; RGB -> ACI - Lee Mac
;; Args: r,g,b - [int] Red, Green, Blue values
(defun LM:RGB->ACI ( r g b / c o )
(if (setq o (vla-getinterfaceobject (LM:acapp) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2))))
(progn
(setq c (vl-catch-all-apply (function (lambda ( ) (vla-setrgb o r g b) (vla-get-colorindex o)))))
(vlax-release-object o)
(if (vl-catch-all-error-p c)
(prompt (strcat "\nError: " (vl-catch-all-error-message c)))
c
) ;;; end GrSnap-subs
(GrSnap-subs)
(setq ll (list 'LM:grsnap:snapfunction 'LM:grsnap:displaysnap 'LM:grsnap:snapsymbols 'LM:grsnap:parsepoint 'LM:grsnap:snapmode 'LM:OLE->ACI 'LM:OLE->RGB 'LM:RGB->ACI))
(setq doc (vla-get-activedocument (LM:acapp)))
(setq spc (vla-get-block (setq alo (vla-get-activelayout doc))))
(setq cmd (getvar (quote cmdecho)))
(setvar (quote cmdecho) 0)
(setq ape (getvar (quote aperture)))
(setvar (quote aperture) 10)
(setq pdm (getvar (quote pdmode)))
(setvar (quote pdmode) 35)
(setq osf (LM:grsnap:snapfunction))
(setq osm (getvar (quote osmode)))
(if (equal 0 (getvar (quote undoctl)))
(if command-s
(command-s "_.undo" "_all")
(vl-cmdf "_.undo" "_all")
(if
(or
(not (equal 1 (logand 1 (getvar (quote undoctl)))))
(equal 2 (logand 2 (getvar (quote undoctl))))
(if command-s
(command-s "_.undo" "_control" "_all")
(vl-cmdf "_.undo" "_control" "_all")
(if (equal 4 (logand 4 (getvar (quote undoctl))))
(if command-s
(command-s "_.undo" "_auto" "_off")
(vl-cmdf "_.undo" "_auto" "_off")
(while (equal 8 (logand 8 (getvar (quote undoctl))))
(if command-s
(if command-s
(command-s "_.undo" "_begin")
(vl-cmdf "_.undo" "_begin")
(while
(not
(or
(eq "" (setq bname (getstring t "\nBlock to Insert: ")))
(tblsearch "BLOCK" bname)
(princ "\nBlock not found.")
(setq loop t)
(while (and loop (setq grr (grread t 7 0))); exit on ENTER or picked point
(redraw)
(setq loop
(cond
((= 2 (car grr)) ; keyboard input
(setq key (cadr grr))
(cond
((= key 13) ; ENTER- where done here
(and ent (entdel ent))
(princ "\nUser Quit.")
nil ; exit loop
((member (chr key) '("I" "i")) ; Insert with OSNAP
(vl-cmdf "_.move" ent "" "_non" lastpt)
(while (= (logand (getvar "cmdactive") 1) 1)
(vl-cmdf "\\")
nil ; exit loop
((member (chr key) '("L" "l")) ; Left or CCW
(vl-cmdf "_.rotate" ent "" "_non" ip 90.0)
t ; stay in loop
((member (chr key) '("R" "r")) ; Right or CW
(vl-cmdf "_.rotate" ent "" "_non" ip -90.0)
t ; stay in loop
((princ "\nInvalid Keypress.") t)
) ; end cond
((= 3 (car grr)) ; point picked, make final insertion
(setq ip (osf (cadr grr) osm))
nil ; exit
((or (= 12 (car grr)) (= 5 (car grr))) ; point from mouse, update object
(if (not lastpt) ; first time through
(progn
(setq lastpt ip)
(vl-cmdf "_.-insert" bname "_S" 1.0 "_R" 0.0 "_non" ip)
(setq ent (entlast))
(if (> (distance ip lastpt) 0.00001)
(vl-cmdf "_.move" ent "" "_non" lastpt "_non" ip)
(setq lastpt ip)
((and (= (car grr) 11) (= (cadr grr) 1000)) ; shift+right click
(progn
(initdia)
(if command-s
(command-s "_.osnap")
(vl-cmdf "_.osnap")
t ; stay in loop
) ; end cond
) ; end (setq loop)
) ; while
(initget "Yes No")
(setq ch (cond ( (getkword "\nDo you want to explode and purge inserted block [Yes/No] : ") ) ("Yes")))
(if (= ch "Yes")
(progn
(vl-cmdf "_.explode" (entlast))
(while (< 0 (getvar (quote cmdactive)))
(vl-cmdf "")
(vl-cmdf "_.-purge" "_b" bname "_n")
(*error* nil)
)HTH.
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
