Using Meta AI in AutoCAD with Python
daniel_cadext
Advisor Advisor
daniel_cadext
Sorry to spam the forums, but I thought this was cool
import traceback
from pyrx_imp import Rx, Ge, Gi, Db, Ap, Ed, Cv
from meta_ai_api import MetaAI
def PyRxCmd_SupZuck():
    try:
        ai = MetaAI()
        while True:
            res = Ed.Editor.getString(1, "\n>>>: ")
            if res[0] != Ed.PromptStatus.eOk:
                return
            zuckSaid = ai.prompt(message=res[1])
            print(zuckSaid['message'])
    except Exception as err:
        traceback.print_exception(err)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
daniel_cadext
Might be better in a palette
https://github.com/CEXT-Dan/PyRx/tree/main/PySamples/wxWidgets/PyChat
Sea-Haven
In some programs have added a HELP button, this can open Word doc, run an animation, open txt, open pdf and so on. IN DCL HELP can be a button, ok_cancel_help button. Or a custom button. Also ok_cancel_help_info button are built in.
daniel_cadext
I remember Clippy
This is quite different than a static help though.  IMHO, it’s kind of a parlor trick at the moment.
Sea-Haven
Nice idea like a look up index say when have a pop menu can ask say "Plot A1" which matches help for plotting A1 sheet layouts lisp.
daniel_cadext
That’s the ticket!
let’s say, ask AI to write an AutoLISP routine to plot all the layouts in a drawing.
And AI pops out a result.  This is wrong, but.. the idea is, the result can be parsed and executed
When AI gets better, and it will, you can just tell AutoCAD to do a task, by verbal command or at the prompt
daniel_cadext
Also, how to give AI more context.. to where you can ask questions like.
Please estimate the material cost using material A vs material B, considering inflation and delivery costs
AI will need to know the delivery date, what’s in the drawing etc. I imagine Excel will have this for bean counters.
Please analyze this drawing for mistakes.. : )
