Pass arguments to "c:" commands
christian_paulsen98V29
Message 1 of 15
Ive found out how to call the gatte command using "c:" instead of "command". However i cant figure out how to pass arguments into the command line after getting gatte started. Ideally after the gatte command is started i can input the following. "B" "DWGSTATE" "STATE" keyword "YES"
(defun c:RELEASESTATE ()
(initget "PRELIMINARY RELEASED")
(if (setq keyword (getkword "[Preliminary/Released]: <Released>"))
	(c:gatte)
Replies (14)
Message 2 of 15
paullimapa
already answered when you posted this in your other thread
Paul Li
IT Specialist
@The Office
Message 3 of 15
He did not. That was a different way of doing it using vla commands, im trying to simplify it into not using vla commands.
It also didnt work. When it came to the "yes" at the end of the arguments, it wasn't getting that input. It was changing the attribute to literally say "Released yes" and then you had to still click yes at the end.
Message 4 of 15
paullimapa
Your better option is to run vla functions which are way more flexible than GATTE which requires Express Tools to be loaded. An example of implementation can be found here:
https://www.cadtutor.net/forum/topic/58824-gatte-w-mtext-or-alternative/?do=findComment&comment=4873...
Just replace the Block, Attribute Tag name & new value with yours in the code.
Paul Li
IT Specialist
@The Office
Message 5 of 15
paullimapa
here's a version that modifies your code but without using vla functions:
; RELEASESTATE
; OP:
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/pass-arguments-to-quot-c-quot-commands/m-p/12779080#M466161
(defun c:RELEASESTATE (/ blknam ent keyword n ss sslen tagnam)
 (setq blknam "DWGSTATE" ; block name
       tagnam "STATE"    ; attribute tag name
 (if (setq ss (ssget "_X" (list '(0 . "INSERT")(cons 2 blknam))))
  (progn
   (initget "Preliminary Released")
   (setq keyword (getkword "Specify keyword [Preliminary/Released]: "))
   (setq sslen (sslength ss) n 0)
   (repeat sslen
    (setq ent (ssname ss n))
    (setpropertyvalue ent tagnam keyword)
    (setq n (+ 1 n))
   ) ; repeat
   (princ(strcat"\nFound " (itoa sslen) " Blocks matching name [" blknam "]"))
  ) ; progn
  (princ(strcat"\nFound no Blocks matching Name [" blknam "]"))
 ) ; if
 (princ)
) ; defun
Paul Li
IT Specialist
@The Office
Message 6 of 15
john.uhden
@christian_paulsen98V29 ,
The only way c: functions can accept input in the same way as AutoCAD commands is to provide them with input arguments, one for one.  But I don't know of anybody who does that because they typically just want to call the command with no arguments and have the function prompt them for the inputs.
Now you might want to try using vlax-add-cmd first.  But I think you would be better just to realize the limitation and create a regular function that accepts arguments.
John F. Uhden
Message 7 of 15
paullimapa
This modified version works but again using vla
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "gatte B DWGSTATE STATE " keyword "\rYes\r"))
Paul Li
IT Specialist
@The Office
Message 8 of 15
paullimapa
Totally agree...like this version which defines your own gatte that accepts arguments:
; RELEASESTATEA
; OP:
(defun c:RELEASESTATEA (/ gatte keyword)
 ; gatte similar to c:gatte function but with following arguments:
 ; blk-arg = block name
 ; tag-arg = attribute tag name
 ; val-arg = attribute value
(defun gatte (blk-arg tag-arg val-arg / ent n ss sslen)
 (if (setq ss (ssget "_X" (list '(0 . "INSERT")(cons 2 blk-arg))))
  (progn
   (repeat sslen
    (setpropertyvalue ent tag-arg val-arg)
    (setq n (+ 1 n))
   ) ; repeat
   (princ(strcat"\nFound " (itoa sslen) " Blocks matching name [" blk-arg "]"))
  ) ; progn
  (princ(strcat"\nFound no Blocks matching Name [" blk-arg "]"))
 ) ; if
) ; defun gatte
; main function
 (if (setq keyword (getkword "Specify keyword [Preliminary/Released]: "))
   (gatte "DWGSTATE" "STATE" keyword)
 (princ)
) ; defun
Paul Li
IT Specialist
@The Office
Message 9 of 15
I looked at that other version on cad tutor that looked like it had kinda the same code as the one you wrote without the vla stuff. However i couldnt 100% figure out how to rework into what i need. I saw where you put in the block name but didnt see where to put in the attribute name.  I guess my problem with all the vla stuff is that i dont fully understand it and it looks overwhelming whenever i see it in code.
I did have a question though. In the beginning of both of the codes it does an ssget and selects all the blocks with the chosen name. Does this select all the blocks in the entire drawing or will it only select all the blocks in your current workspace? Say like if im in model space it will only change the blocks in model space.
Below is a copy of the final code i ended up using. I liked it because it was short and easy, i guess the only downfall is that it relys on the express tools. I also didnt like having to add the second line in the if statement because it seemed redundant but i couldnt find another way to make it work if the user just pressed enter and it returned 'nil'.
	(vl-load-com)
		(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "gatte b dwgstate state " keyword "\nyes "))
		(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "gatte b dwgstate state RELEASED\nyes "))
Message 10 of 15
	(vl-load-com)
Message 11 of 15
paullimapa
Yes, the link I provided and the two code versions I wrote use the same ssget method to select ALL instances of the given block name which in your case is called "DWGSTATE" both in Model & all Layouts matching what the Express Tools Gatte function does.
Cadtutor code:
(setq ss (ssget "X" '((0 . "INSERT")(2 . "NP TITLEBLOCK INFO")))) ; block name is "NP TITLEBLOCK INFO"
My Code #1:
My Code #2: which defines own gatte function with three arguments: block name, tag name & new attribute value:
 (if (setq ss(ssget "_X" (list '(0 . "INSERT")(cons 2 blk-arg))))
; then towards the end of code call the new gatte function:
As for your new modified code, what you could do is to actually define a default global keyword variable like this:
 (or **keyword** (setq **keyword** "RELEASED")) ; setup default
This assume no other code is using **keyword**
Then the following lines of code will respond to the initget
If an enter is press to accept the default **keyword** then keyword will be set equal to the global variable
Else the global variable will be reset using the new selected keyword value:
 (setq keyword (getkword (strcat "Specify keyword [PRELIMINARY/RELEASED] <" **keyword** ">: ")))
 (if (not keyword)
  (setq keyword **keyword**) ; hit enter to accept default
  (setq **keyword** keyword) ; reset default to new entry
 ) ; if
Then lastly run the vla command but using the version I provided which completes itself without further interaction:
Yes, there are more lines of code...but all automated if you want to run RELEASESTATE again in the same drawing.
; RELEASESTATE
; OP:
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/pass-arguments-to-quot-c-quot-commands/m-p/12781153#M466205
(defun c:RELEASESTATE (/ keyword)
 (vl-load-com)
 (if (not keyword)
 ) ; if
 (princ) ; clean exit
) ; defun
Paul Li
IT Specialist
@The Office
Message 12 of 15
Sea-Haven
Re "Say like if im in model space it will only change the blocks in model space." You can use a 410 filter for the current space. Or "Model" for model space only.
(if (setq ss(ssget "_X" (list '(0 . "INSERT")(cons 2 blk-arg)(cons 410 (getvar 'ctab))))
Message 13 of 15
paullimapa
you can learn a lot by opening Express Tools gatte.lsp file & see what it does:
         (Setq
            NA (GetString T "\nEnter new text: ")
            SS1 (SsGet "_X"
                 (List
                    (Cons 0 "INSERT")
                    (Cons 2 bn)
                    (Cons 66 1)
Notice the gatte.lsp's ssget function adds an additional (cons 66 1) which tells AutoCAD to select the block that also has attributes ignoring other blocks that do not.
FYI: Notice the "_X" that follow ssget tells AutoCAD to automatically select all both in Model & Layouts
PS: to find the location of gatte.lsp at the command prompt enter:
(findfile "gatte.lsp")
Paul Li
IT Specialist
@The Office
Message 14 of 15
hak_vz
Passing arguments to c:command
(defun somecommand (arg1 arg2 argn / local_1 local_2 .....)
(defun c:somecommand nil (somecommand (arg1 arg2 argn)))
Miljenko Hatlak
Message 15 of 15
john.uhden
Blast it all again... kicked out with "authentication failed" right as I submitted!!
And I didn't save a draft of what I had written.  It was something like this...
@hak_vz ,
I wouldn't call your method as passing arguments to a command function, as your method does not use local variables but only references symbols that are global.
As I had stated, you might as well use just a regular function that accepts arguments as inputs (which by definition are local).
But there is a kind of work-around using vlax-add-cmd.
For example:
(defun test ( / a b c)
  (setq a (getstring "\nFirst: "))
  (setq b (getstring "\nSecond: "))
  (setq c (getstring "\nThird: "))
  (print (strcat a " " b " " c))
  (princ)
(vlax-add-cmd "Test" 'test)
Command: (setvar "cmdecho" 0) 0
Command: (command "test" "One" "Two" "Three")
"One Two Three" nil
Of course there is a limitation... Unlike AutoCAD commands, you must provide the exact number of input arguments as the function requests.
BUT, your function could be embellished to deal with a null response to any input prompt and carry on appropriately.
I would still stick with a plain function, unless you are into scripts where this technique could be helpful, especially with users1(-5), useri1(-5), and userr1(-5).
John F. Uhden
