Need Help Creating MLeader Style Arrowhead Type
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have been trying to create 2 MLeader styles. They're very similar except their arrowheads are different. The first is the standard "_closed_filled", and the second would use the "_dot".
No matter what I try, it causes an error.
I've tried using vla-put-ArrowheadType, vla-put-ArrowheadBlock, and vla-put-ArrowheadStyle, but none of these will work.
(defun CreateMLeaderStyle (dwg_scale / CMS_MLeaderStyles newMleaderStyle CMS_ColorObject)
(setq mlCounter 0)
(while (< mlCounter 2)
(if (= mlCounter 0) (setq newMlStyleName "Test"))
(if (= mlCounter 1) (setq newMlStyleName "Test_Dot"))
(if (tblsearch "STYLE" "ROMANS")
(progn
(setq CMS_MLeaderStyles (vla-item (vla-get-Dictionaries (vla-get-ActiveDocument (vlax-get-acad-object))) "ACAD_MLEADERSTYLE"))
(if (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list CMS_MLeaderStyles newMlStyleName)))
(progn
(setq newMleaderStyle (vla-AddObject CMS_MLeaderStyles newMlStyleName "AcDbMLeaderStyle"))
(if (= mlCounter 0)
(progn
(vla-put-ArrowSymbol newMleaderStyle "_closed_filled")
;(vla-put-ArrowheadType newMleaderStyle "_closed_filled")
(vla-put-ArrowSize newMleaderStyle 4.40)
(if (= mlCounter 1)
(progn
(vla-put-ArrowSymbol newMleaderStyle acMLeaderArrowheadDot)
;(vla-put-ArrowheadBlock newMleaderStyle 3)
(vla-put-ArrowSize newMleaderStyle 1.5)
(vla-put-MaxLeaderSegmentsPoints newMleaderStyle 2)
(vla-put-EnableDogleg newMleaderStyle 1)
(vla-put-DogLegLength newMleaderStyle 5.0) ;Landing length
(vla-put-ScaleFactor newMleaderStyle dwg_scale)
(vla-put-TextStyle newMleaderStyle "ROMANS")
(vla-put-TextAngleType newMleaderStyle 1)
(vla-put-TextBottomAttachmentType newMleaderStyle 0) ;Middle
(vla-put-TextHeight newMleaderStyle 2.20)
(vla-put-TextLeftAttachmentType newMleaderStyle 1) ;Middle
(vla-put-TextRightAttachmentType newMleaderStyle 1) ;Middle
(vla-put-TextTopAttachmentType newMleaderStyle 0) ;Middle
(vla-put-LandingGap newMleaderStyle 1.0)
(princ "\n ** Error: MLeader style already exists")
(princ "\n ** Error: textstyle does not exist")
(setq mlCounter (+ mlCounter 1))
) ;ends while
(setvar "cmleaderstyle" "Test")
(princ)
I get these:
error: ActiveX Server returned an error: Parameter not optional
error: ActiveX Server returned the error: unknown name: ArrowheadType
error: ActiveX Server returned the error: unknown name: ArrowheadBlock
Thanks in advance for any help.
