Need a list of constants in visual lisp
dvertz
Message 1 of 13
dvertz
I currently have about 400 of the defined constants but I am still missing some. I don't know how many I am missing, but I know I am missing "acmiddlecenter". I am looking for the one that does the middle left. I am currently guessing at "acmiddleleft" but I won't know for sure until I run my function to see if it fails. I would just like to get the list of all constants that are defined. I searched the internet but I am just know hitting on the right keywords to find it. Thanks.
Civil 3D 2022,
Windows 10 Pro, x64, Nvidia Quadro P1000
Intel Core i9-11900k; 3.50GHz, 32 GB RAM, 500GB WD BLACK M.2
Replies (12)
Message 2 of 13
daniel_cadext
For ActiveX? Python wrappers have them generated here
https://github.com/CEXT-Dan/PyRx/blob/main/pyrx/PyAx.pyi
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 3 of 13
Kent1Cooper
I'm not quite sure I understand what you're asking, because it sounds like you want variables, which is the opposite of constants, but which you can define [you can't "define" a constant, which is fixed -- things like pi].  But in any case, does the (atoms-family) AutoLisp function [>here<] do what you want?
Kent Cooper, AIA
Message 4 of 13
daniel_cadext
I’m assuming something like (setq acmiddlecenter 5), if that's the case the link I posted might be helpful
Message 5 of 13
paullimapa
You can see them with command:
FIELD
Field category: Other
Field names: LispVariable
Paul Li
IT Specialist
@The Office
Message 6 of 13
komondormrex
find *middle* masked
Command: LSP
Enter an option [Commands/Functions/Variables/Load]: V
Enter Variables to list <*>: *middle*
ACALIGNMENTMIDDLE             (INT)
ACALIGNMENTMIDDLECENTER       (INT)
ACALIGNMENTMIDDLELEFT         (INT)
ACALIGNMENTMIDDLERIGHT        (INT)
ACATTACHMENTMIDDLE            (INT)
ACATTACHMENTMIDDLEOFBOTTOM    (INT)
ACATTACHMENTMIDDLEOFTOP       (INT)
ACATTACHMENTPOINTMIDDLECENTER (INT)
ACATTACHMENTPOINTMIDDLELEFT   (INT)
ACATTACHMENTPOINTMIDDLERIGHT  (INT)
ACHORIZONTALALIGNMENTMIDDLE   (INT)
ACMIDDLECENTER                (INT)
ACMIDDLELEFT                  (INT)
ACMIDDLERIGHT                 (INT)
ACTOLMIDDLE                   (INT)
ACVERTICALALIGNMENTMIDDLE     (INT)
ac* masked, guess all acad's. with logging on all are written to the current log file.
Command: LSP
Enter an option [Commands/Functions/Variables/Load]: va
Enter Variables to list <*>: ac*
AC0DEGREES                    (INT)
AC1_1                         (INT)
AC1_10                        (INT)
AC1_100                       (INT)
AC1_128IN_1FT                 (INT)
AC1_16                        (INT)
AC1_16IN_1FT                  (INT)
AC1_2                         (INT)
ACWHITE                       (INT)
ACWINDOW                      (INT)
ACWORLD                       (INT)
ACXLINE                       (INT)
ACYELLOW                      (INT)
ACZERO                        (INT)
ACZOOMSCALEDABSOLUTE          (INT)
ACZOOMSCALEDRELATIVE          (INT)
ACZOOMSCALEDRELATIVEPSPACE    (INT)
Message 7 of 13
Moshe-A
@dvertz hi,
why realy care what value these constant holds, in expression i use them like they were integers
(setq alignments (+ acAlignmentAligned acAlignmentMiddle acAlignmentFit acAlignmentTopLeft))
and if i need the value...use (prompt (itoa acAlignmentMiddle))
Moshe
Message 8 of 13
dvertz
Daniel,
Yes. Active X
Thanks, This is very close to what I was looking for and then some.
Civil 3D 2022,
Message 9 of 13
dvertz
There are many constants defined in lisp to use instead of variables. Variables can change. The "acmiddlecenter" is a constant that never changes.
Civil 3D 2022,
Message 10 of 13
dvertz
Ah. I did not know this. Its a perfect list. I just wish I could now extract them as text. As my intended use for the text is to place them in my "word file" for UltrEdit. I use UltraEdit for alot of my coding when I am working on a machine without Autocad installed. And having syntax highlighting is great.
Civil 3D 2022,
Message 11 of 13
dvertz
Wow. That looks like is gives the list I was looking for. I just used "*" to get all of the constants/variables. Now I will need to sort through them.
Civil 3D 2022,
Message 12 of 13
dvertz
I don't care what the value is of the constant.
See my reply to paullimapa. I explained there what my use for the list of constant is being used for.
Civil 3D 2022,
Message 13 of 13
dvertz
To follow up ... this worked perfectly. I pasted the list into UltraEdit and sorted through them to remove items I did not need. That did not take long. Then I did a find and replace to remove the "(INT)" and others. Then performed a trim trailing spaces. I copied and pasted that list into the "word file" and saved it. The result was perfect. The Orange are the new constants from the list.
Civil 3D 2022,
