Deleting Non Display Attribute
davidEPN6Z
davidEPN6Z
How can I delet all the non display attribute in a dynamic block using LISP or other script.
komondormrex
check this one. deletes all invisible attributes in a selected dynamic block.
(defun c:delete_invisible_atts (/ dyn_block count)
  (setq count 0)
  (vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
  (setq dyn_block (vlax-ename->vla-object (car (entsel "\nSelect dynamic block with invisible attributes: "))))
  (if (minusp (vlax-get dyn_block 'isdynamicblock))
    (vlax-map-collection (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (vla-get-effectivename dyn_block))
      '(lambda (object)
        (and (= "AcDbAttributeDefinition" (vla-get-objectname object))
           (or (minusp (vlax-get object 'invisible))
             (zerop (vlax-get object 'visible))
           (null (vla-erase object))
           (setq count (1+ count))
           (command "_attsync" "_n" (vla-get-effectivename dyn_block))
  (princ (strcat "\n" (itoa count) " deleted"))
  (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  (princ)
davidEPN6Z
Thanks. Is this going also to delete visible attribute that are not display on the drawing because visabiliy state. I need to delete those attribut too.
komondormrex
modified to delete both.
davidEPN6Z
I don't see the modified script.  The first one delete all invisble attribute but leaves the visibel one that not display (because of visbility state) intake.
komondormrex
 it is in message 2.
davidEPN6Z
Thank you Its working perfect.
