Need a CODE to convert a plane view into ISO view
sharpl
sharpl
Lloyd Beachy had a TIP on CADALYST few years back with this warning: For tip to function correctly, you must ensure that the downloaded file name matches the file name
displayed in the Rename File To field. Please rename downloaded files when necessary. The renamed advise is as follows:
Rename File To:Tip2052: Iso_Views.lsp
1. ":" is not allowed in a file name
2. Error message is error: bad argument type: streamp nil
Anyone could help please?
devitg
just rename to
Iso_Views.lsp
devitg
find attached
kensulu2000
I am having the same Streamp nil error when I launch the Iso_Views.lsp routine. Is there a fix and if so how?
iso : dialog {label="Isometric Views";
: row {
: boxed_column {label="Include:";
: toggle {key="line";label="Lines";}
: toggle {key="circle";label="Circles";}
: toggle {key="arc";label="Arcs";}
: toggle {key="text";label="Text";}
: toggle {key="lwpolyline";label="LWPlines";}
: toggle {key="spline";label="Splines";}
: boxed_column {label="Select drawing plane:";
: row {
spacer_0;
: image_button {key="left";width=10;aspect_ratio=1;fixed_width=true;color=254;}
: image_button {key="right";width=10;aspect_ratio=1;fixed_width=true;color=254;}
spacer_0;
: row {
spacer_0;
: image_button {key="top_left";width=10;aspect_ratio=1;fixed_width=true;color=254;}
: image_button {key="top_right";width=10;aspect_ratio=1;fixed_width=true;color=254;}
spacer_0;
spacer;
spacer;
: row {:spacer{width=17;}cancel_button;help_button;spacer_1;}
; error: bad argument type: streamp nil
kensulu2000
So it just so happen I figured this one out. When I made a Lisp folder for some reason windows was having me provide Administrator Permission to write and access the folder. So I enabled the permissions and tested it and it works. Not so sure if the name of the folder is the permission issue or not but that is what the issue was in it not working. Thought I would let people know if you try to save a file from say Autolisp and do a save to that folder and if it says you need permissions then that is the issue. Activate the permissions and it should work.
Hope this helps others who may encounter this with the Iso_Views.lsp routine.
