RGB to HEX
RGB to HEX
adaptacad
RGB to HEX
adaptacad
Hello guys, does anyone have any function to convert RGB Colors to HEX?
example:
255,0,0
to
# FF0000
_gile
You can start from this:
(defun int2hex (i / s a)
  (setq s "")
  (cond
    ((= i 0) "0")
    (T
     (while (> i 0)
       (setq a (rem i 16)
	     i (lsh i -4)
	     s (strcat
		 (if (< a 10)
		   (chr (+ 48 a))
		   (chr (+ 55 a))
		 s
(defun padLeft (s i x)
  (while (< (strlen s) i)
    (setq s (strcat x s))
  s
(defun rgb2hex (r g b)
  (strcat
    (padLeft (int2hex r) 2 "0")
    (padLeft (int2hex g) 2 "0")
    (padLeft (int2hex b) 2 "0")
(rgb2hex 255 0 0) => "FF0000"
Gilles Chanteau
GileCAD
GitHub
adaptacad
@_gile  That's right, thank you!
adaptacad
ronjonp
Solved HERE too.
