My lisp stalls out, will only complete if I hit enter key a number of times.
SKEMPP
SKEMPP
I can't figure out what is wrong, the lisp runs if I hit the enter key the same number of times that there are tables selected.
The lisp goes through a selection of tables and sets each cell to unlocked. It will be part of a bigger lisp eventually.
(defun C:Unlock_Table_Cells (/)
  (vl-load-com)
  (princ
    "\n*** Select Table's to Unlock ***"
  ) ;_ end of princ
  (if
    (setq ss (ssget
        (list '(0 . "ACAD_TABLE")
        ) ;_ end of list
      ) ;_ end of ssget
    ) ;_ end of setq
     ;THEN do this
     (SETQ LEN  (SSLENGTH SS)
    COUNT 0
     ) ;_ end of SETQ
     ;ELSE do this
  ) ;_ end of if
  (WHILE (< COUNT (- LEN 1))
  ;;(WHILE (< COUNT LEN)
     ;(PRINC COUNT)
    (SETQ TblEntityName
   (ssname SS COUNT)
   TblObj
   (vlax-ename->vla-object TblEntityName)
    ) ;_ end of SETQ
   ; (progn
      (setq nRows (- (vla-get-rows TblObj) 1))
      (setq nCols (- (vla-get-columns TblObj) 1))
      (setq row 1)
      (setq cell 0)
      (grread)
      (vla-put-RegenerateTableSuppressed TblObj :vlax-true)
      (while (<= row nRows)
 (while (<= cell nCols)
   (vla-setcellstate TblObj row Cell 0)
   (setq cell (1+ cell))
     ;(princ (strcat "\nRow : " (itoa row) " , cell " (itoa cell))
     😉 ;_ end of princ
 ) ;_ end of while
 (setq row (1+ row))
 (setq cell 0)
      ) ;_ end of while
      (vla-put-RegenerateTableSuppressed TblObj :vlax-false)
      (SETQ COUNT (+ 1 COUNT))
   ; ) ;_ end of progn
  ) ;_ end of WHILE
) ;_ end of defun
(princ)
dlanorh
Try commenting out the (grread) line
I am not one of the robots you're looking for
SKEMPP
Thankyou, That works.
Steve
cadffm
Just for my information: You erased the grread.
New drawing, new table, one cell set to locked, copy this table two times and start your tool.
Check this cell in all three tables, are all unlocked?
In my previous test not! But no time to looking for the issue.
Thx in advance for your answer.
Sebastian
SKEMPP
Yes, you are right. Its still broken.
Steve
cadffm
You should re-think about this:
 (WHILE (< COUNT (- LEN 1)) <- current
  ;;(WHILE (< COUNT LEN)       <- meaningful
Sebastian
SKEMPP
Thank you, You are absolutely correct.
Steve
