My LISP only lets me select one table at a time
wjbGQR94
wjbGQR94
Hi there,
I have made a simple lisp that removes the property overrides of a table but I need to individually click each table.
I would like to be able to select all the tables on a drawing at once and use this command
Any advice would be most welcome!
Thanks!
xuantientutungXUK6E
(setq ss (ssget "x" (list (cons 0 "INSERT") (cons 2 "zi3042sht")))
Use this code above for reference.
it will select what you want in active drawing depended on the condition (list (cons 0 "INSERT") (cons 2 "zi3042sht"))
ВeekeeCZ
Here you go.
(vl-load-com)
(defun c:RPO ( / toggle ss i)
  (setq toggle 0)
  (if (setq ss (ssget '((0 . "ACAD_TABLE"))))
    (repeat (setq i (sslength ss))
      (vla-cleartablestyleoverrides (vlax-ename->vla-object (ssname ss (setq i (1- i)))) toggle)))
  (princ)
wjbGQR94
Exactly what I needed thank you so much
