duct lsp edit some lsp
I found it lsp
double line elbow maker lsp
I hope you fixed the contents a bit
I attached sample dwg and lsp file.  some help guys
https://lispbox.wordpress.com/2014/11/25/double-line-elbow-maker-v-1-5/
_Tharwat
Here is my professional HVAC Program that you can download it from my website:
https://autolispprograms.wordpress.com/hvac/hvac-application/
oh, thanks but that's not the answer I want...
Sea-Haven
If its not what you want just remember you can try yourself to fix it. People on here offer there services for free. Will you ? The answer is out there did you try googling ?
Tharwat hi from BIGAL 👍
_Tharwat
Thank you BIGAL. 😊
thanks for reply
I got it and I will accept it in a hunble way
Sea-Haven
Try this drag a L across the 3 lines.
; multifillet 3 lines
; by Alanh  [email protected] Feb 2020
(defun c:mfillet2 (/ pt1 pt2 pt3 pt4 obj1 obj2 lst1 lst2 lst dist1 dist2 x ss ss2)
(setq pt1 (getpoint "\nPick outside"))
(setq pt2 (getpoint pt1 "\nPick inside"))
(setq pt3 (getpoint pt2 "\nPick outside"))
(setq rad  (getreal "\nEnter inside radius"))
  (setq lst (list pt1 pt2))
  (setq ss (ssget "F" lst (list (cons 0 "*line"))))
  (setq lst (list pt2 pt3))
  (setq ss2 (ssget "F" lst (list (cons 0 "*line"))))
  (if (= (sslength ss) (sslength ss2))
    (progn
      (command "line" pt1 pt2 "")
      (setq obj1 (vlax-ename->vla-object (entlast)))
      (command "Line" Pt2 pt3 "")
      (setq obj2 (vlax-ename->vla-object (entlast)))
      (setq lst1 '())
      (repeat (setq x (sslength ss))
        (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
       (setq pt4 (vlax-curve-getclosestpointto obj pt2))
        (setq dist1 (distance pt2 pt4))
        (setq lst1 (cons (list dist1 pt4) lst1))
      (setq lst1 (vl-sort lst1
                          (function (lambda (e1 e2)
                                            (< (car e1) (car e2))
      (setq lst2 '())
      (repeat (setq x (sslength ss2))
        (setq obj (vlax-ename->vla-object (ssname ss2 (setq x (- x 1)))))
        (setq lst2 (cons (list dist1 pt4) lst2))
      (setq lst2 (vl-sort lst2
      (vla-delete obj1)
      (vla-delete obj2)
      (setq d1 (- (car (nth 1 lst2))(car(nth 0 lst2))))
      (setq d2 (- (car (nth 2 lst2))(car(nth 1 lst2))))
      (setq x 0)
        (setvar 'filletrad rad)
        (setq pt1 (cadr (nth x lst1)))
        (setq pt2 (cadr (nth x lst2)))
        (command "fillet" pt1 pt2)
        (setvar 'filletrad (+ rad d1))
        (setq x (+ x 1))
        (setvar 'filletrad (+ rad d1 d2))
        (setq x (+ x 1))
  (princ)
(c:mfillet2)
