Multiple Initget / getkword Within a function
alex.dickmann
alex.dickmann
I am very new to lisp and am a bit confused. I am trying to use two separate instances of initget and getkwords.
Basically I want to ask the user two separate questions, each of which have 2 different answers. Can anyone shed some light on what I might be doing wrong here?
Generic Example:
(initget 1 "A B")
(setq ans (getkword "\nChoose [A/B]: "))
(initget 1 "C D")
(setq ans1 (getkword "\nChoose [C/D]: "))
END OF EXAMPLE
I would eventually use thier choices to these two questions later on in my actual function.
When I do this though, it doesnt seem to recognize C & D and keywords.
Not sure how to work around this. I learn best from simple examples.
Thank you in advance!
paullimapa
Sea-Haven
Try this look inside code for more examples. A replacement for initget.
(if (not AH:Butts)(load "Multi radio buttons.lsp")) ; loads the program if not loaded already
(setq ans1 (ah:butts 1 "V"   '("Please choose A B " "A" "B"))) 	; ans holds the button picked value as a string
(setq ans2 (ah:butts 1 "V"   '("Please choose C D " "C" "D" ))) 	; ans holds the button picked value as a string
ВeekeeCZ
There is nothing wrong with your generic example. It works flawlessly.
(defun c:test ()
  (initget 1 "A B")
  (initget 1 "C D")
  (princ "\nFirst choice: ")
  (princ ans)
  (princ "\nSecond choice: ")
  (princ ans1)
  (princ)
john.uhden
@ВeekeeCZ ,
Works for me too.
His/her problem is probably subsequent to those inputs.
John F. Uhden
alex.dickmann
Thanks for the help all.  It must be something I goofed up somewhere else like John mentioned.
Thanks again @ВeekeeCZ
paullimapa
no you didn't goof up...read my previous reply again where I provided the thread explaining the reason for what you've encountered.
Paul Li
IT Specialist
@The Office
