Multiple drawings in to single drawing
HR2323
Message 1 of 21
HR2323
Combine multiple drawing into a single drawing.
Replies (20)
Message 2 of 21
Kent1Cooper
I'm not sure what you're asking.  Yes, they can be combined, in several ways.  You can make a New drawing, and either XREF or INSERT the others into it.  Or you can open any of those drawings and XREF or INSERT all the others into it.  If you need to keep each of them as a separate drawing file in addition to combining them, then use Xref; if you want everything consolidated and do not need the separate ones, use Insert to reduce the overall memory used slightly.  Put them in Model space since they're all Model information, and make a Paper space Layout for each sheet, with Viewports that look into Model space at the contents for each sheet.  I would also put most of the title-block information [everything that is common to all drawings] into either a Block definition to be Inserted into each Layout or a separate drawing file to be Xref'd into each [but only the right-edge parts, since the borders are not all the same size], and remove those parts from Model space, since they are not Model-type information.
Kent Cooper, AIA
Message 3 of 21
HR2323
Yes Sir, I have need to lisp, which is to collect multiple files into single.  Please download a copy of the requirement.
Message 4 of 21
Kent1Cooper
Have you tried Searching the Forums?  I would guess that a way to do something like that is probably already here somewhere.
Kent Cooper, AIA
Message 5 of 21
hmsilva
Hi sanju2323,
save the attached file in one 'Support File Search Path'.
I did use Lee Mac's List Box to create the DCL for dwg's selection.
The file will write a '.scr' file, and the script will load the '.lsp' file to combine multiple drawing into a single drawing.
You have to ensure that none of DWGs is open.
Open a new dwg, load the code and type Combine
Hope this helps,
Henrique
Message 6 of 21
paullimapa
You can always use the built-in XREF command which allows you to select multiple drawings to attach into a single drawing file and then bind them all as inserted blocks.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Paul Li
IT Specialist
@The Office
Message 7 of 21
HR2323
Henrique, Thank You Very Much.Smiley Very Happy
Message 8 of 21
hmsilva
You're welcome, sanju2323
Glad I could help! 🙂
Henrique
Message 9 of 21
When I try this, I cant get the results. I'm Using Autocad 2012 and I got below commend box replays. And new drawing created "Combine" that one is empty.
Please Help me with this.
Message 10 of 21
Dear Henrique,
I combined drawings but, the lines are broken after combination, what should ı do ?
Message 11 of 21
Invalid selection error??
@hmsilvawrote:
Hi sanju2323,
Hope this helps,
Henrique
Message 12 of 21
vladimir_michl
A simple LISP utility - InsertBlks - will combine all DWG files from a folder. See:
http://www.cadforum.cz/cadforum_en/batch-insert-of-multiple-dwg-files-into-one-tip8966
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Message 13 of 21
I have installed the lsp but Im getting the following error message when i try to run it in AutoCAD for Mac 2016
Command: *Cancel*
Command:
Command:
Command: _import
Command: lisp*Cancel*
Command: APPLOAD Combine.LSP successfully loaded.
Command:
Command:
Command: COMBINE
** Error: no function definition: ACET-UI-PICKDIR **
Message 14 of 21
maratovich
Maybe this will help you:
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 15 of 21
Hi
Message 16 of 21
maratovich
Have you tried the program specified in the previous post (Revers) ?
www.kdmsoft.net
Message 17 of 21
 Hi maratovich,
Yes i tried the addin Revers but the Webpage does not  allow me to download a trial version. could you send me a copy?
Message 18 of 21
maratovich
Here is the link of the trial version:
https://www.kdmsoft.net/revers/download/Revers_setup.zip
Program website -https://www.kdmsoft.net/revers.html
Contacts are indicated on the program website.
Write in the letter your address, send it directly.
www.kdmsoft.net
Message 19 of 21
ktsaleej
Insert multiple drawing files ( .dwg or .dxf ) to an AutoCAD sheet
http://ktsaleej.blogspot.com/2017/09/insert-multiple-drawing-files-dwg-or.html
In above link you can generate AutoLISP(.lsp) program to insert multiple drawing files ( .dwg or .dxf ) to an AutoCAD sheet.
Just fill below form and generate your AutoLISP(.lsp) program to insert multiple drawing files.
Message 20 of 21
hmsilva,
thank you this is working good.
