Is there a way to make a linetype that is always at back in the draw order?
smells9mm
smells9mm
I am fairly new to autocad and revit and this is my first experience with the forum so please forgive my ignorance.
I like to use a wide width polyline to mark shearwalls on my drawings,  They always come in at the front of the draw order and I need them to always be at the back.  I would like to make my "shearwall" linetype always come it at the back.  Any ideas?
Kent1Cooper
There's no way that I know of for a linetype to be defined to behave that way.  I would suggest having them on their own Layer, and a little command could easily be defined to put everything on that Layer in back, which you could invoke when you're done drawing such things, and/or before closing the drawing.  Something like [untested]:
(defun C:SW2B (); = Shear Walls {to} Back
  (command "_.draworder" (ssget "_X" '((8 . "YourSWLayerName"))) "" "_back")
  (princ)
Kent Cooper, AIA
rkmcswain
In addition to the previous reply, here are some routines that may assist you.
R.K. McSwain     | CADpanacea | on twitter
smells9mm
That worked great.  Thank you!
