Mtext lisp
Mtext lisp
C.Utzinger
Mtext lisp
C.Utzinger
HI
I have this code. Now i want to add some text for the commandline while im making the Window for the mtext, i tried a lot, but nothing works...
(defun C:<T-1-50-2mm()
	(command "-layer" "_m" "-I-Text_020" "_co" "2" "-I-Text_020" "_l" "continuous" "-I-Text_020" "")
	(command "-stil" "simplex7-10" "simplex.shx" "10" "0.7" "0" "_n" "_n" "_n")
	(command "_.mtext" pause pause "")
	(command "_mtedit" "l")
	(command "layerp")
	(command "-layer" "_co" "2" "-I-Text_020" "_l" "continuous" "-I-Text_020" "")(prin1)
) ; end of defun
Please help!!!
ВeekeeCZ
Not sure what you want... try this...
(defun C:<T-1-50-2mm( / p1 p2)
  (command "_.-style" "simplex7-10" "simplex.shx" "10" "0.7" "0" "_n" "_n" "_n")
  (setq p1 (getpoint "\nMtext: first point of window: "))
  (setq p2 (getcorner p1 "\nMtext: second point of window: "))
  (command "_.mtext" "_none" p1 "_none" p2 "")
  (command "layerp")
  ) ; end of defun
C.Utzinger
Yes!!!!!!!!!!!!!!!!!!!!
Thank you again and again.... 🙂
Regards
C.Utzinger
The text appears perfectly, but with this code there is no Windows while drawing the two Points.
Is it possible to have also the Windows like with the normal command  "_.mtext"?
ВeekeeCZ
Well, just different one... Anyway, either you can add some prompts... (version 1) or you can even suppress some of original prompts by setting the CMDECHO sysvar off (version 2).
(defun C:<T-1-50-2mm1()
  (command "_.style" "simplex7-10" "simplex.shx" "10" "0.7" "0" "_n" "_n" "_n")
  (command "_.mtext")
  (princ "\nMtext: first point: ")
  (command pause)
  (princ "\nMtext: second point: ")
  (command pause "")
  (command "layerp")
  ) ; end of defun
(defun C:<T-1-50-2mm2( / ocmd *error*)
    (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
    (setvar 'CMDECHO ocmd)
    (princ))
  (setq ocmd (getvar 'CMDECHO))
  (setvar 'CMDECHO 0)
  (command "_.mtext")
  (command pause)
  (command pause "")
  (command "layerp")
  (prin1)
  ) ; end of defun
C.Utzinger
Perfect that's better (Option 1)
Thank you very much!!!!
