change everything back to beinging when you enter @ a Relative Coordinates
cadking2k5
cadking2k5
I have a special Line command but I want to make it when I type in a (@) Relative Coordinates the settings go back to the why it was before the command and then it reads the Relative Coordinates what (IF function would I use
Ranjit_Singh
Nothing special about IF function. You just need to program the logic based on your needs. If you are the author of the special line command then share the code and someone might be able to help.
