UCS Follow
UCS Follow
C.Utzinger
UCS Follow
C.Utzinger
Hello
Is there a possibility to turn back "ucsfollow" automatically to 0 in case of cancelling the Routine by user (ESC ESC ESC...) 🙂 ?
(defun c:<BKSDrehen()
	(command "bksymbol" "au")
	(setvar "ucsfollow" 1)
	(princ "\nUCSFOLLLOW = 1")
	(princ "\nAusrichtung wählen: ")
	(command "_ucs" "_z" pause pause)
	(setvar "ucsfollow" 0)
	(princ "\nUCSFOLLOW = 0")
	(prin1)
) ; end of defun
Thank you...
krzysztof.psujek
off course there is a possibility to bring back old variables setting during error.
You need read about error handling
for example this:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/error-trapping/td-p/4886888
http://www.afralisp.net/autolisp/tutorials/error-trapping.php
http://www.lee-mac.com/errorhandling.html
Chris
ВeekeeCZ
The code or an error could be the same... add what you want to reset in case of error.
(defun c:<BKSDrehen (/ *error*)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
    (princ))
  (prin1)
  ) ; end of defun
C.Utzinger
Thank you very much!!!
I just fixed a little error. There was one ")" to much.
    (princ))
  (prin1)
  ) ; end of defun
ВeekeeCZ
It's good that you're thinking about it! Unfortunately in this case -- it was good as it was.
C.Utzinger
Ups
You are wright. My fault! I had an error!!!
Thank you very much
C.Utzinger
How can i delete the wrong solution?
