MText Background Mask settings LISP
Message 1 of 14
Hello everyone,
Just wandering if you know of a LISP routine to set all mtext to a background mask size of 1.1 rather than the AutoCAD standard 1.5.
If anyone has any ideas how to achieve this please let me know.
Cheers.
Replies (13)
Message 2 of 14
Jonathan3891
Here ya go
color: 8
border: 1.1
(defun c:mblank ( / js n dxf_ent)
	(setq js (ssget '((0 . "MTEXT"))))
	(cond
		(js
			(repeat (setq n (sslength js))
				(setq dxf_ent (entget (ssname js (setq n (1- n)))))
				(entmod (append dxf_ent '((90 . 1) (63 . 8) (45 . 1.1) (441 . 0))))
Jonathan Norton
Blog | Linkedin
Message 3 of 14
Not sure what i am doing wrong but it wont work sorry DSM_dude.
Message 4 of 14
This is what i get.
Command: '_script
Command: (defun c:mblank ( / js n dxf_ent)
(_> (setq js (ssget '((0 . "MTEXT"))))
(_> (cond
((_> (js
(((_> (repeat (setq n (sslength js))
((((_> (setq dxf_ent (entget (ssname js (setq n (1- n)))))
((((_> (entmod (append dxf_ent '((90 . 1) (63 . 8) (45 . 1.1) (441 . 0))))
((((_> )
(((_> )
((_> )
(_> )    - It gets stuck here so I press enter then -
C:MBLANK
Is there input i meant to be giving?!
Thanks in advance.
Message 5 of 14
hmsilva
Dustin,
try to load the DSM_dude's code in VLIDE or save the file and load it to test...
This Lee Mac's tutorials should be helpful.
How to Run an AutoLISP Program
An Introduction to the Visual LISP IDE
Hope this helps,
Henrique
Message 6 of 14
Jonathan3891
Its working fine on my end.
Try this working lisp.
Jonathan Norton
Blog | Linkedin
Message 7 of 14
Sorry mate this Script is still not working correctly.
What am I doing wrong?
Message 8 of 14
Jonathan3891
After seeing your post above, your trying to load this like a script. This isn't a script and cant be loaded as such.
Use the command APPLOAD and load it through that window.
After its loaded, type "MBLANK"
Are you using AutoCAD Lite?
Jonathan Norton
Blog | Linkedin
Message 9 of 14
How you change the color to match the drawing background color?
Message 10 of 14
Jonathan3891
This will set the color to match the background.
	(cond
		(js
				(entmod (append dxf_ent '((90 . 3) (63 . 256) (45 . 1.1) (441 . 0))))
Jonathan Norton
Blog | Linkedin
Message 11 of 14
Does this apply to MLEADER as well?
Message 12 of 14
Jonathan3891
No that code only works for Mtext.
If you need something for Mleaders, try this;
(defun c:test (/ ss i)
  (if (setq ss (ssget '((0 . "MULTILEADER"))))
    (repeat (setq i (sslength ss))
      (setpropertyvalue (ssname ss (setq i (1- i))) "MText/BackgroundFill" 1)))
  (princ)
Jonathan Norton
Blog | Linkedin
Message 13 of 14
Thank you! This is great. I do have one more request....can you set the background mask offset on the MLEADER to 1.1 (or match the MTEXT)?
Message 14 of 14
calDRPMQ
Community Visitor
Community Visitor
How do you set it to use the drawing background colour?
