Toggle a variable
Toggle a variable
doni49
Mentor Mentor
Toggle a variable
doni49
Here's a little lsp routine that I started using many years ago when I needed to toggle a variable (one that is either 0 or 1).
(setq v (- 1 v))
If the variable starts out as 1, then subtract 1 from 1 and get 0.  If the variable starts out as 0, then subtract 0 from 1 and get 1.
I just thought someone might find it useful.  It works better than using an if statement.
Command: (setq v 1)
1
Command: (setq v (- 1 v))
0
1
0
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
rkmcswain
Another way  Smiley Indifferent
_$ (setq x 0)
0
_$ (setq x (abs (1- x)))
1
0
1
0
R.K. McSwain     | CADpanacea | on twitter
ВeekeeCZ
But you need twice as much functions than @doni49! 🙂
(setq does not count)
Shneuph
Old Code:
(Defun C:TLC-Toggle_Perspective (/)
  (if (= (getvar "perspective") 0)
(setvar "perspective" 1)
(setvar "perspective" 0)
) (princ) );Defun
New Code:
  (setvar "perspective" (- 1 (getvar "perspective")))
  (princ)
  );Defun
Thanks!
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Kent1Cooper
(setq v (- 1 v))
I've used the same approach, too, for ages.
Here's an approach I've also used for such things when the options are not limited to only 0 and 1.  It will cycle around one step at a time through all possible integer values if they range from 0 upward.  [For example, the CenterType VLA Property of a Diameter or Radius Dimension (it's not anywhere in entity data, but there are entries about it in extended data) holds one of 3 values -- 0, 1 or 2 -- and determines whether it has crosshairs, crosshairs+lines, or neither.]
If the 'poss' value below represents the number of possible integer values [from 0 up to one less than the 'poss' number], then this will cycle through them:
(setq v (rem (1+ v) poss))
So, for example, with something that can have values from 0 through 4 [that is, 5 possible values] --
Set up the circumstances:
(setq poss 5); possible values 0 through 4
(setq v 3); [arbitrary starting value]
Then here we go:
Command: (setq v (rem (1+ v) poss))
4 ; [moves up 1 from what it was]
0 ; [cycles back to 0 after maximum value]
1 ; [then steps upward again from there]
2
3
It works with any integer value for 'poss'.
It could also be adjusted easily enough to suit different situations, like an other-than-0-upward range of values such as from -3 through 3.
Kent Cooper, AIA
rkmcswain
And the original one from @doni49 is faster too.
(defun date2sec ()
  (setq s (getvar "DATE"))
  (setq seconds (* 86400.0 (- s (fix s))))
(setq x 0)
(defun C:1 (/ timer)
  (setq timer (date2sec))
  (repeat 1000000
  (princ (rtos (- (date2sec) timer) 2 10))
(defun C:2 (/ timer)
  (repeat 1000000
    (setq x (- 1 x))
_$ (c:1)
0.3690183163
_$ (c:2)
0.2619981766
_$
Now if I ever need to run this function 1 million times, I'll have to figure out how to spend that extra 1/10 of a second of free time.
Smiley Happy
doni49
LOL
Don Ireland
