Move blocks to nearest detected curve
I am looking for a LISP program that will allow me to window/intersection select multiple blocks and move them horizontally to the nearest intersection with a line/p-line/spline in a selected direction. I also need the program to automatically detect the nearest curve in the selected direction. I do not want to have to select a curve manually.
The command would have the following prompts:
1. Select blocks
> I select the blocks with a window or intersect then hit the space bar
2. Prompt direction
> I select a direction
> Blocks are moved to the nearest line/polyline/spline in the selected direction
I have included screenshots showing the desired steps.
dlanorh
This has been answered before, but you have a new wrinkle.
Try this.
(defun rh:ss2lst( ss opt / cnt lst)
  (cond ( (and ss (= (type ss) 'PICKSET))
          (repeat (setq cnt (sslength ss)) (setq lst (cons (ssname ss (setq cnt (1- cnt))) lst)))
          (if opt (setq lst (mapcar 'vlax-ename->vla-object lst)))
  );end_cond
  lst
);end_defun
(vl-load-com)
(defun c:mbo ( / *error* c_doc c_spc mv_lst ss llst v cnt n_pt blk i_pt n_obj xlst lst)
  (defun *error* ( msg )
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : " msg " occurred.")))
    (princ)
  );_end_*error*_defun
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
        c_spc (vlax-get-property c_doc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
        mv_lst (list '(0.0 1.0 0.0) '(0.0 -1.0 0.0) '(-1.0 0.0 0.0) '(1.0 0.0 0.0))
        ss (ssget "_X" '((0 . "LINE,LWPOLYLINE,POLYLINE,SPLINE")))
        llst (rh:ss2lst ss t)
        ss nil
  );end_setq
  (cond (llst
          (prompt "\nSelect Blocks to Move : ")
          (setq ss (ssget "_:L" '((0 . "INSERT"))))
          (cond (ss
                  (initget 1 "Up Down Left Right")
                  (setq v (cond ( (getkword "\nSelect Move Direction : [Up/Down/Left/Right] <Up> ")) ("Up")))
                  (setq v (nth (vl-position v (list "Up" "Down" "Left" "Right")) mv_lst))
                    (setq n_pt nil xlst nil lst nil
                          blk (ssname ss (setq cnt (1- cnt)))
                          i_pt (cdr (assoc 10 (entget blk)))
                          n_obj (vlax-invoke c_spc 'addray i_pt (mapcar '+ i_pt v))
                    );end_setq
                    (foreach x llst (setq xlst (cons (vlax-invoke n_obj 'intersectwith x acextendnone) xlst)))
                    (vla-delete n_obj)
                    (mapcar '(lambda (x) (setq lst (cons (list (distance i_pt x) x) lst))) (vl-remove-if '(lambda (x) (not x)) xlst))
                    (setq n_pt (car (mapcar 'cadr (vl-sort lst '(lambda (x y) (< (car x) (car y)))))))
                    (if n_pt (vlax-invoke (vlax-ename->vla-object blk) 'move i_pt n_pt))
                  );end_repeat
                (t (alert "NO Blocks selected"))
          );end_cond
        (t (alert "NO Lines selected"))
  );end_cond
  (princ)
);end_defun
I am not one of the robots you're looking for
Thank you, this is is just what I am looking for!
I was wondering if you could add a conditional so the blocks ignore curves on locked layers. I would also like to handle an edge case: if a block is already located on a line/curve then blocks move to the next curve. I have attached photos of the edge case. Thank you again.
dlanorh
Is this to be done automatically (test if blk is on a line) or as an option (additional input asking this to be taken into account, Yes No answer, if Yes impliment it, if No as normal)?
Yes, automatically
dlanorh
OK. Tested and works in my version (2012).
(defun rh:ss2lst( ss opt / cnt ent elst lyr lst)
            (setq ent (ssname ss (setq cnt (1- cnt)))
                  elst (entget ent)
                  lyr (tblsearch "layer" (cdr (assoc 8 elst)))
            );end_setq
            (if (/= 4 (logand 4 (cdr (assoc 70 lyr)))) (setq lst (cons ent lst)))
          );end_repeat
  );end_cond
  lst
);end_defun
(vl-load-com)
    (princ)
        ss nil
  );end_setq
  (cond (llst
          (cond (ss
                    );end_setq
                    (vla-delete n_obj)
                    ;;EDGE CASE HERE
                    (setq lst (vl-sort lst '(lambda (x y) (< (car x) (car y)))))
                    (if (zerop (caar lst))
                      (setq n_pt (cadr (mapcar 'cadr lst)))
                      (setq n_pt (car (mapcar 'cadr lst)))
                    );end_if
                  );end_repeat
          );end_cond
  );end_cond
  (princ)
);end_defun
This is perfect, thank you very much.
